Custom Property Format in iLogic
Message 1 of 16
I would like to set the custom property format for all user paramters from an iLogic code. This is what I've come up with. It runs, but it does not seem to alter the custom property format. What am I doing wrong here?
DimoPartDocAsPartDocument
oPartDoc=ThisApplication.ActiveDocument
DimoParameterAsParameter
ForEachoParameterInoPartDoc.ComponentDefinition.Parameters
oParameter.ExposedAsProperty=True
ShowUnitString=True
ShowLeadingZeros=True
ShowTrailingZeros=False
Precision=kTwoDecimalPlacesPrecision
NextoParameter
Replies (15)
Message 2 of 16
xiaoyan.qi
Hi, Gary
here is the VBA code for your request
Sub ChangeFormat()
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    Dim oParameter As Parameter
    For Each oParameter In oPartDoc.ComponentDefinition.Parameters.UserParameters
        Dim oFormat As CustomPropertyFormat
        Set oFormat = oParameter.CustomPropertyFormat
        oParameter.ExposedAsProperty = True
        oFormat.PropertyType = kTextPropertyType
        oFormat.Precision = kTwoDecimalPlacesPrecision
        oFormat.Units = "in"
        oFormat.ShowUnitsString = True
        oFormat.ShowLeadingZeros = True
        oFormat.ShowTrailingZeros = False
    Next oParameter
End Sub
i tried in iLogic, in iLogic code, you need to change the enumeration to the related value, see my code below:
        oFormat.PropertyType = 85249
        oFormat.Precision = 85507
Next oParameter
let me know if it works
Mick
Message 3 of 16
xiaoyan.qi
update the iLogic code
DimoFormatAsCustomPropertyFormat
ForEachoParameterInoPartDoc.ComponentDefinition.Parameters.UserParameters
oFormat=oParameter.CustomPropertyFormat
oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType
oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kTwoDecimalPlacesPrecision
oFormat.Units="in"
oFormat.ShowUnitsString=True
oFormat.ShowLeadingZeros=True
oFormat.ShowTrailingZeros=False
NextoParameter
the enumerate type in iLogic need to add the whole statement from Inventor.***
Message 4 of 16
That works great! Thank you.
How do I get the value of a User Parameter unit type? I'll need to do an if statement for "in" or "mm" and set the custom property format accordingly.
Message 5 of 16
I think I figured this out. Thanks for the help!
SyntaxEditor Code Snippet
'*** Begin Code for setting Custom Property Types for User Parameters ***
''' If Exposed As Property = True then check for "in" or "mm" and
''' Set Custom Property Types accordingly.
'*** Dim variables....
'*** For Each User Parameter....
IfoParameter.ExposedAsPropertyThen
IfoParameter.Units="mm"Then
oFormat.Units="mm"
ElseIfoParameter.Units="in"Then
oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kThreeDecimalPlacesPrecision
oFormat.Units="in"
oFormat.ShowLeadingZeros=False
Else
EndIf
Else
EndIf
NextoParameter
'*** End Code for setting Custom Property Types for User Parameters ***
Message 6 of 16
LSA-skan
Hi
I need this code in Inventor 2013, but it´s not working...
Error message..:
Error on Line 8 : 'DimoPartDocAsPartDocument' is not declared. It may be inaccessible due to its protection level.
Error on Line 10 : 'DimoParameterAsParameter' is not declared. It may be inaccessible due to its protection level.
Error on Line 11 : 'DimoFormatAsCustomPropertyFormat' is not declared. It may be inaccessible due to its protection level.
Error on Line 15 : 'ForEachoParameterInoPartDoc' is not declared. It may be inaccessible due to its protection level.
Error on Line 16 : 'IfoParameter' is not declared. It may be inaccessible due to its protection level.
Error on Line 17 : 'IfoParameter' is not declared. It may be inaccessible due to its protection level.
Error on Line 17 : End of statement expected.
Error on Line 18 : 'oParameter' is not declared. It may be inaccessible due to its protection level.
Error on Line 19 : 'oParameter' is not declared. It may be inaccessible due to its protection level.
Error on Line 26 : 'ElseIfoParameter' is not declared. It may be inaccessible due to its protection level.
Error on Line 26 : End of statement expected.
Error on Line 27 : 'oParameter' is not declared. It may be inaccessible due to its protection level.
Error on Line 28 : 'oParameter' is not declared. It may be inaccessible due to its protection level.
Error on Line 35 : 'Else' must be preceded by a matching 'If' or 'ElseIf'.
Error on Line 36 : 'End If' must be preceded by a matching 'If'.
Error on Line 36 : 'EndIf' statements are no longer supported; use 'End If' instead.
Error on Line 37 : 'Else' must be preceded by a matching 'If' or 'ElseIf'.
Error on Line 38 : 'End If' must be preceded by a matching 'If'.
Error on Line 38 : 'EndIf' statements are no longer supported; use 'End If' instead.
Error on Line 39 : 'NextoParameter' is not declared. It may be inaccessible due to its protection level.
Im not a pro in anyway regarding this, so im sure it´s something simple im unaware of...
Hope some of you guys, can help me sort this out for the new version of Inventor...
/LSA-Skan
Message 7 of 16
If you cut and paste that, you'll need to add the spaces back in....
"DimoPartDocAsPartDocument" should be "Dim oPart As PartDocument", etc.
I think when I cut and pasted the code into here it removed the spaces.
Message 8 of 16
LSA-skan
ahh.. Thanks Gary
Works like a charm now.. 🙂
Do you know if theres is a way to specify the parameters..?
Like if i want Parameter "Diameter" to have Units String = False & Trailing Zeros = False
but on all others parameters Units string = True
/LSA.Skan
Message 9 of 16
LSA-skan
...Another thing...
I have now made the rule so it changes both the User Parameters and the Model Parameters, but i would like to change the Sheet Metal Parameters as well, if it is a sheet metal part, but i don't know the code for it..
These lines doesn't work..:
If oPartDoc.ComponentDefinition.Type = kSheetMetalComponentDefinitionObject Then
For Each oParameter In oPartDoc.ComponentDefinition.Parameters.SheetMetalParameters
Message 10 of 16
You can try to nest another if statement to get to a specific parameter like this... I'm not sure if you are even able to do this with the sheet metal parameters because they are controlled by a style.
Dim oUserParam As UserParameter
For Each oUserParam In oPartDoc.ComponentDefinition.Parameters.UserParameters
	oUserParamName = oUserParam.Name
If oUserParamName = "Diameter" Then
	If oUserParam.ExposedAsProperty Then
		If oUserParam.Units = "mm" Then
			oFormat = oUserParam.CustomPropertyFormat
			oUserParam.ExposedAsProperty = True
			oFormat.PropertyType = Inventor.CustomPropertyTypeEnum.kNumberPropertyType
			oFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kTwoDecimalPlacesPrecision
			oFormat.Units = "mm"
		ElseIf oUserParam.Units = "in" Then
			oFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kThreeDecimalPlacesPrecision
		Else
	Else
		oUserParamValue = Parameter(oUserParam.Name)
		iProperties.Value("Custom", oUserParam.Name) = UCase(oUserParamValue)
Else
		ElseIf oUserParam.Units = "deg" Then
			oFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kOneDecimalPlacePrecision
			oFormat.Units = "deg"
		ElseIf oUserParam.Units = "ul" Then
			oFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision
			oFormat.Units = "ul"
		Else
	Else
Next oUserParam
Message 11 of 16
LSA-skan
Hi Gary
thanks.. !! I will try with this.. 🙂
Regarding the Sheetmatal parameters... then my thought is, that if i can do it manually, then i should also be able to do it with an iLogic rule..?? but as mentioned, im not a pro with this.. 🙂
/LSA-Skan
Message 12 of 16
Glad to help. I'd investigate the code but I can't commit the time right now. What I've done is set up User Parameters to drive the sheet metal parameters. For example I drive thickness with a User Parameters named "Thickness" but you have to disable the sheet metal default checkbox "Use Thickness from Rule" to do that.
Message 13 of 16
LSA-skan
All good..! thanks for the effort.. i will give you a Kudos for your help 🙂
Message 14 of 16
Hi My requirment is slightly different so I hope someone can provide me with some assistance please.
I need to change the custom property format for a single specified fx parameter (<G_L>) as created by Inventor Frame generator, so that it drops the "mm" units and the trailing zero's.
The trickier part is that I would like to run an iLogic rule from the assembly level so that the custom property changes are made to the "<G_L>" fx parameter in all the parts in the assembly.
Wayne
Message 15 of 16
Please help.
I have tried to use this iLogic code but am getting the following error code:
Rule Compile Errors in Rule4, in Part1
Error on Line 5 : 'For' must end with a matching 'Next'.
Error on Line 15 : 'NextoParameter' is not declared. It may be inaccessible due to its protection level.
Please can someone suggest a solution.
Message 16 of 16
Try adding a space between "Next" and "oParameter" in "NextoParameter"
