Visual Studio - Addin to add tab in the Ribbon
mgFNR8M
mgFNR8M
Hi.
In the past, I have found the source code of an add-in created in Visual Studio to create a custom Ribbon tab.
I am looking for this, but I can't find it. It's possible that it wasn't shared on Autodesk forums.
Does anyone have this addin source code? I want to create a custom Ribbon tab for myself, and it can only be done with VS, as far as I know.
Thanks in advance.
florian_wenzel
you have this File in your Computer.
Go to:
C:\Users\Public\Documents\Autodesk\Inventor <version>\SDK
Install the SDK
DeveloperTool.msi
JelteDeJong
You can check my tutorial about creating an addin. "Creating an Inventor Addin"
Jelte de Jong
Blog: hjalte.nl - github.com
AMCr2
Maxim-CADman77
@JelteDeJong
Please check your e-mail for some critics of your article.
Please vote for Inventor-Idea Text Search within Option Names
Maxim-CADman77
@JelteDeJong
I believe I did everything as In your article but resulting Add-In returns error "Class Not Registered" during initialization.
My code is - https://github.com/CadMan77/JelteDeJongAddinVS22.git
What I'm missing?
JelteDeJong
Last night I tried to find the problem with your code but did not manage to find the problem.
In your mail you wanted wrote that you could not find the class "AbstractRule". The GIT repository that comes with the tutorial has several versions. That class is only used in older versions of the add-in and first steps of the tutorial. In later versions it is not used any more. Here you can find all versions:
https://github.com/hjalte79/MyILogicAddin/commits/master
Here you find the class in an old version of the code:
https://github.com/hjalte79/MyILogicAddin/blob/b01f7fdf24c9ac54fe507cdbf51fb758b087acb6/MyILogicAddi...
Jelte de Jong
