Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Visibility control - drawing environment
kresh.bell
Message 1 of 8
kresh.bell
is it possible to create an iLogic that would have visibility control (on/off) in the drawing environment for all parts that have the prefix "-" in the body name. Like this one for example
Replies (7)
Message 2 of 8
Ivan_Sinicyn
Hi @kresh.bell
Try this
Sub Main()
    ' Check that the active document is a drawing
    If ThisApplication.ActiveDocument.DocumentType <> kDrawingDocumentObject Then
        MessageBox.Show("This code must be executed in a drawing environment.", "Error")
        Exit Sub
    End If
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    ' Iterate through all sheets in the drawing
    For Each oSheet As Sheet In oDrawDoc.Sheets
        ' Iterate through all views on the sheet
        For Each oView As DrawingView In oSheet.DrawingViews
            ' Get the model document associated with the view
            Dim oRefDoc As Document
            oRefDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
            ' Check document type and call processing
            If oRefDoc.DocumentType = kPartDocumentObject Then
                ProcessPartInView(oView, oRefDoc)
            ElseIf oRefDoc.DocumentType = kAssemblyDocumentObject Then
                ProcessAssemblyInView(oView, oRefDoc)
            End If
        Next
    Next
    ' Update the drawing
    oDrawDoc.Update
End Sub
Sub ProcessPartInView(oView As DrawingView, oDoc As PartDocument)
    ' Get the component definition of the part
    Dim oCompDef As PartComponentDefinition
    oCompDef = oDoc.ComponentDefinition
    ' Iterate through all solid bodies in the part
    For Each oBody As SurfaceBody In oCompDef.SurfaceBodies
        ' Check if the body name starts with "-"
        If Left(oBody.Name, 1) = "-" Then
            ' Turn off visibility of the body in the drawing view
            oView.SetVisibility(oBody, False)
        End If
    Next
End Sub
Sub ProcessAssemblyInView(oView As DrawingView, oDoc As AssemblyDocument)
    ' Get the component definition of the assembly
    Dim oCompDef As AssemblyComponentDefinition
    ' Iterate through all component occurrences in the assembly
    For Each oOcc As ComponentOccurrence In oCompDef.Occurrences
        ' Get the document associated with the occurrence
        Dim oSubDoc As Document
        oSubDoc = oOcc.Definition.Document
        ' Process only nested parts
        If oSubDoc.DocumentType = kPartDocumentObject Then
            ProcessPartInView(oView, oSubDoc)
        ElseIf oSubDoc.DocumentType = kAssemblyDocumentObject Then
            ' Recursively process nested assemblies
            ProcessAssemblyInView(oView, oSubDoc)
        End If
    Next
End Sub
INV 2026.4
Message 3 of 8
kresh.bell
thanks for your code, but unfortunately appears that error
Message 4 of 8
Ivan_Sinicyn
@kresh.bell
One more attempt🤣
Sub Main()
        Exit Sub
    End If
            ' Check if referenced document is valid
            If oRefDoc Is Nothing Then Continue For
                ProcessAssemblyInView(oView, oRefDoc, New Collection)
            End If
        Next
    Next
    oDrawDoc.Update
End Sub
    ' Check if inputs are valid
    If oView Is Nothing Or oDoc Is Nothing Then Exit Sub
    ' Check if component definition is valid
    If oCompDef Is Nothing Then Exit Sub
        ' Check if body is valid and its name starts with "-"
        If oBody IsNot Nothing AndAlso Left(oBody.Name, 1) = "-" Then
            Try
            Catch ex As Exception
                ' Log error silently or handle as needed
            End Try
        End If
    Next
End Sub
Sub ProcessAssemblyInView(oView As DrawingView, oDoc As AssemblyDocument, oParentOccurrences As Collection)
        ' Check if occurrence is valid
        If oOcc Is Nothing Then Continue For
        Try
            Continue For ' Skip if document cannot be accessed
        End Try
        ' Check if sub-document is valid
        If oSubDoc Is Nothing Then Continue For
        ' Clone the parent occurrences collection and add the current occurrence
        Dim oNewParentOccurrences As New Collection
        For Each item In oParentOccurrences
            oNewParentOccurrences.Add (item)
        Next
        oNewParentOccurrences.Add (oOcc)
        ' Process nested parts
            ProcessNestedPartInView(oView, oSubDoc, oNewParentOccurrences)
            ProcessAssemblyInView(oView, oSubDoc, oNewParentOccurrences)
        End If
    Next
End Sub
Sub ProcessNestedPartInView(oView As DrawingView, oDoc As PartDocument, oParentOccurrences As Collection)
    If oView Is Nothing Or oDoc Is Nothing Or oParentOccurrences Is Nothing Then Exit Sub
            Try
                ' Create a proxy for the surface body in the context of the full occurrence path
                Dim oBodyProxy As Object = oBody
                If oParentOccurrences.Count > 0 Then
                    Dim oCurrentOcc As ComponentOccurrence
                    ' Apply proxy creation for each level of nesting in reverse order
                    For i = oParentOccurrences.Count To 1 Step -1
                        oCurrentOcc = oParentOccurrences(i)
                        Dim oTempProxy As Object
                        oCurrentOcc.CreateGeometryProxy(oBodyProxy, oTempProxy)
                        If oTempProxy IsNot Nothing Then
                            oBodyProxy = oTempProxy
                        End If
                    Next
                End If
                ' Turn off visibility of the body proxy in the drawing view
                If oBodyProxy IsNot Nothing Then
                    oView.SetVisibility(oBodyProxy, False)
                End If
            End Try
        End If
    Next
End Sub
Edited: UPD.
INV 2026.4
Message 5 of 8
kresh.bell
Hi @Ivan_Sinicyn
much better, but it seems like it doesn't work if it's in a subassembly
but it works if it's a part placed assembly
Message 6 of 8
Ivan_Sinicyn
@kresh.bell
I updated the second post with the code 5 minutes ago. Check it again. It's working for me.
INV 2026.4
Message 7 of 8
kresh.bell
unfortunately, dont't works for me for sub sub sub assembly here
Message 8 of 8
Ivan_Sinicyn
Okay, two problems.
1. I misunderstood the task at hand.😬
2. I made visibility to be disabled for solids, but not for components containing them. But, I have it turned off at any nested levels and I don't understand why it is not turned off for you.
I will later change to disable visibility for parts that contain such solids.
Can you make a small assembly with a drawing file where the code doesn't work?
INV 2026.4
