virtual component
virtual component
martinhoos
Message 1 of 12
virtual component
martinhoos
Hello together,
i created a code that tooks an virtual component from an excel file. The problem that i have is, if the component allready exists, i get an error. How can i fix that problem? If compnent exist, delete it and place an new one in... but i dont know, how.
Thank you in advance
Regards
Martin
Dim retVal
Dim Menge As String = "Menge"
GoExcel.Open("c:\iproperties\iproperties.xlsx", "data")
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oMatrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix
Dim oOcc As ComponentOccurrence
'oOcc = oAsm.ComponentDefinition.Occurrences.AddVirtual("EXAMPLE", oMatrix)
oOcc = oAsm.ComponentDefinition.Occurrences.AddVirtual(GoExcel.CellValue("Z2"), oMatrix)
Dim oCompDefVirtual As VirtualComponentDefinition = oOcc.Definition
'CREATE AND SET THE IPROP
Dim oPropertySet As PropertySet = oCompDefVirtual.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
iProperties.Value(GoExcel.CellValue("Z2") & ":1","Summary", "Title")=GoExcel.CellValue("AA2")
iProperties.Value(GoExcel.CellValue("Z2") & ":1","Summary", "Subject")=GoExcel.CellValue("BB2")
iProperties.Value(GoExcel.CellValue("Z2") & ":1","Summary", "Author")=GoExcel.CellValue("Z2")
iProperties.Value(GoExcel.CellValue("Z2") & ":1","Summary", "Manager")=GoExcel.CellValue("AF2")
iProperties.Value(GoExcel.CellValue("Z2") & ":1","Project", "Description")=GoExcel.CellValue("AA2") + "  " + GoExcel.CellValue("BB2")
customPropertySet = ThisDoc.Document.PropertySets.Item _
("Inventor User Defined Properties")
Try
         prop= customPropertySet.Item(Menge)
Catch
            customPropertySet.Add("", Menge)
End Try
Menge = InputBox("Bitte die Menge eingeben, z.B. 2,5", "iLogic", iProperties.Value("Custom", "Menge"))
Replies (11)
Message 2 of 12
You can use Try - Catch method also when you are creating the virtual component.
Message 3 of 12
martinhoos
Thanks RAS,
sounds good - but i dont know how. I do not have so much experience in iLogic. Can you tell me how to do that?
Regards
Martin
Message 4 of 12
Here is how it should work(I didn't test):
Try
Catch ex As Exception
      For Each oOcc In oAsm.ComponentDefinition.Occurrences
          If oOcc.Name = GoExcel.CellValue("Z2") Then
               oOcc.Delete()
          End If
      Next
oOcc = oAsm.ComponentDefinition.Occurrences.AddVirtual("Name of component", oMatrix)
End Try
Message 5 of 12
martinhoos
Dim retVal
Try
               oOcc.Delete()
          End If
      Next
End Try
Try
Catch
End Try
Hello RAS,
thank you for responce... but there is a mistake in the code, i get this message (enclose).
The code i used:
Message 6 of 12
Curtis_Waguespack
Hi martinhoos,
This example shows how to delete existing instances and replace them:
http://inventortrenches.blogspot.com/2013/07/ilogic-add-standard-virtual-parts-from_29.html
I hope this helps.
Curtis
Message 7 of 12
Yes there was a bug in my code. Occurrence name is not equal than part number, occurrence name has ":1" in the end of the name. But we can compare the displayname and this should be the same than the name given when component is created.
There seems to be good sample in Cutris's blog also. The idea seems to be the same.
Try this:
Try
          If oOcc.Definition.Displayname = GoExcel.CellValue("Z2") Then
               oOcc.Delete()
          End If
      Next
oOcc = oAsm.ComponentDefinition.Occurrences.AddVirtual(GoExcel.CellValue("Z2") , oMatrix)
End Try
Message 8 of 12
martinhoos
Thank you Curtis and RAS,
i gambled a couple of hours with both ideas - but i get no result, it is too hard for me. I took the code from RAS into my code. It works only in an empty assembly. If there are parts in, i get following message:
System.MissingMemberException: Der öffentliche Member Displayname für den Typ SheetMetalComponentDefinition wurde nicht gefunden.
bei Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
bei LmiRuleScript.Main()
bei Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
bei iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
or
System.MissingMemberException: Der öffentliche Member Displayname für den Typ PartComponentDefinition wurde nicht gefunden.
Regards
Martin
Message 9 of 12
Sorry one more bug.. (Like I said I didn't test..)
If type of component is virtual component the displayname is under the 'Definition' but with normal component(ipt, iam) displayname is under the document object. So we need to read the displayname only from virtual components.
Try
          If TypeOf oOcc.Definition Is VirtualComponentDefinition Then 'compare only virtual component names
                  oOcc.Delete()
             End If
          End if
      Next
End Try
Off topic: I don't use(and like) iLogic because no debugging available and this topic is good example where debug would be very helpful. I prefer vb.net and VBA. I also think that it would be better to start programming to Inventor with VBA. It would give much more understanding how Inventor API works. If you haven't used/learnd VBA I strongly recommend to do that.
Message 10 of 12
GosponZ
Hi Curtis,
your code working just fine, but I have one question. In QTY I need put number like 0.1 but it will not work. Can you advice how my virtual part will be in BOM in decimal?
Message 11 of 12
martinhoos
Thanks RAS - works perfect!
Message 12 of 12
martinhoos
