Views in DWG
Views in DWG
GosponZ
Views in DWG
GosponZ
Every time i made dwg's i have to create all ort. views but i also need place label for each view. Is it possible with rule to pick view and then choose from list which view label it is. For ex. plan,side lt, side rt isometric etc..
Thank you
Vladimir.Ananyev
Try this rule. Not very convenient but works.
Dim oList As String() = {"AAA","BBB","CCC"}
Dim LabelName As String = InputListBox( _
		"Select Label Name and then Pick Drawing View", _
		oList, "", Title := "Label Names")
If LabelName <> "" Then
	' Get a drawing view selection from the user
	Dim oObject As Object
	oObject = ThisApplication.CommandManager.Pick( _
		SelectionFilterEnum.kDrawingViewFilter, "Pick a feature")
	Dim oView As DrawingView = oObject
	oView.ShowLabel = True
	oView.Label.FormattedText = LabelName
End If
Beep
 cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
GosponZ
Yes, it works thanks alot Mr. Vladimir Smiley Very Happy
