View "Dim" Variable Values
Joseph.Lasser
Joseph.Lasser
This is likely a poor question, but is there a a way to view a list of all declared variables in a rule and their associated values?  For example, please reference the script below:
Dim Test1 = 1
Dim Test2 = 2
Dim Test3 = 3
Dim Sum = Test1+Test2+Test3
Within the rule editor, would there be a way to see that the variable Sum is equal to 6?
cidhelp
Hello @Joseph.Lasser ,
you can log the value using logger:
Joseph.Lasser
Excellent, thank you!
layochim
@Joseph.Lasser i came across this post in my searches.  I have a similar case but i'd like to SUM all the variables without having to do "Test 1 + Test2...etc"  Is there a way of doing this in iLogic?
WCrihfield
If you are talking about a built-in Function, like in Excel, then I do not recall one like that at the moment, but the 'List(Of t)' object has a method like that, when the Type (t) is a numeric type, such as Integer or Double.  For example:
Dim Val1 As Double = 1.5
Dim Val2 As Double = 3
Dim Val3 As Double = 5.5
Dim values As New List(Of Double) From {Val1, Val2, Val3 }
Dim sum As Double = values.Sum
Logger.Info("Sum = " & sum.ToString())
This essentially adds all the Double type values into a new 'List of Double', then since the Type of its entries is Double, its 'Sum' extension method (a Function) is enabled, which returns the Sum of all its entries.
Wesley Crihfield
(Not an Autodesk Employee)
layochim
This is exactly what i was looking for, Thank you!
