View Label - Various Text Sizes
Tim.Orndorf
Tim.Orndorf
I'm working on creating a DWG template for our company. This issue I came across is trying to have (2) different text sizes in the view labels (see image; also be nice if the text was centered, that might simply be a change in the Style Editor, I haven't gotten that far).
The top row is to be 1/4"
The bottom row(s) is to be 1/8"
So far it seems that I can't do this w/o an iLogic rule and the one I tried messes the text up to where all text is 1/4" and all on the same line. Unfortunately I'm not quite smart enough to understand what/how to edit the rule (copied from here: Autodesk Forum Topic ).
After running the iLogic rule
This is the iLogic rule I found
CGBenner
@Tim.Orndorf
Hello and welcome!  I moved this post and the post you liked to the Inventor Programming forum for better findability.  Good luck!
Chris Benner
marcin_otręba
hi,
it's really hard to help you when you do not provide any data , for example - all labels are the same ?  what is inside?
please refer to : Inventor 2025 Help | XML Tags for FormattedText | Autodesk
my suggestion is to use this rule to see how you label is built:
Dim sourcelabel As DrawingViewLabel = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewLabelFilter, "choose source label")
Logger.Info(sourcelabel.FormattedText)
then you can copy it from logger window and put into your rule :
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
oSheets = ThisDoc.Document.Sheets
For Each oSheet In oSheets
	oViews = oSheet.DrawingViews
    	For Each oView In oViews
    		oView.Label.FormattedText = copied text here
    	Next
Next
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders
J-Camper
I believe you can do what you want without iLogic.  The StylesManager has a View Preferences section where you can edit the default view label:
Let me know if this does not achieve your goal
CGBenner
@Tim.Orndorf
Hello, Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
