Video Card / Display Inv 11
I noticed since I have installed 11 that the edge lines and some other
details are missing in close zooms. What is the cause? Is it most likely
that I need to update the Video card driver (NVidia Quadro FX1300 PCIE
Driver Version 6.14.10.6722) Or is it the settings? I currently have the
Graphics set on Full optimization with Direct 3D.
Inventor 10 looks just fine, 11 just a little different, less detail,
choppy.
Is it ok to use the newest driver on NVidia's site? (Vers. 77.18)
Jerry Chasek
> choppy.
> Jerry Chasek
Edges almost sound like an anti-aliasing issue. You could try turning
that up higher (at least 4x). Perhaps try using OpenGL instead of
Direct 3D?
Tom Veldhouse
there is a setting in under tools>document setting on the Drawing tab. set the use bitmap for shaded views to offline only and set the image fidelity fo high.
