VBA Thumbnail iProperty Yields varying quality, file size, and back color
rcolon9E4ZX
Message 1 of 16
rcolon9E4ZX
I am trying to collect thumbnails from the Thumbnail iProperty of a document, since this approach is very fast. The stored thumbnail is always 213x213pixels. Sometimes the resolution is great, and sometimes it is very poor. See image below. Not only that, the good resolution images have a dark gray background for some reason and the low res ones have the default. The file size for the good images is 769KB, which is the same size as a 512x512pixel bitmap from Camera.SaveAsBitmap. The low res files are <100KB.
Quality and back colorQuality and back color
Here is a snippet of VBA code run from Inventor where I acquire the image.
Dim summaryInfo As PropertySet
Dim thumbprop As Property
Dim thumbNail As IPictureDisp
Set summaryInfo = doc.PropertySets.Item("Inventor Summary Information")
Set thumbprop = summaryInfo.Item("Thumbnail")
Set thumbNail = thumbprop.Value 'Get the thumbnail image.
If Not thumbNail Is Nothing Then 'Check that an image was returned.  It's possible for a file to not have a thumbnail.
    ' Write the thumbnail to disk. Size is 213x213. Even if a larger image is imported. Overwrites existing file.
    Call stdole.StdFunctions.SavePicture(thumbNail, strFile)
Else
    'MsgBox "The active document doesn't have a thumbnail."
End If
Any ideas for what is causing this difference in results? Maybe some property in the document? One hypothesis I had, although disproved, is if the Master view rep was the only view rep for the document. Is there something else that is causing this? This seems very odd to me.
Many thanks in advance.
Rafael
Replies (15)
Message 2 of 16
rcolon9E4ZX
I am running on Win10 Inv Pro 2019 x64 Build 330. Surely someone has seen or questioned this behavior before. The thumbnails appear in this fashion within Manage > Bill of Materials in Inventor. All of my files are set the same under the Save tab in iProperties. They are all from the same template. And yet, they store differently on save.
iProperties > SaveiProperties > Save
Message 3 of 16
rcolon9E4ZX
Can someone else confirm this behavior?
Message 4 of 16
Curtis_Waguespack
Hi @rcolon9E4ZX
Due to time, I didn't really look too closely at what you posted other than the problem statement of the original post... but I think this link might offer a solution
https://forums.autodesk.com/t5/inventor-forum/is-there-a-way-to-refresh-all-thumbnails/m-p/7239233#M...
I hope this helps.
Curtis
Message 5 of 16
Curtis_Waguespack
Hi @rcolon9E4ZX .
I looked back at this and realized that something like this might be more what you are after, this version will write out an image file for the top level and  each component of an assembly.
I hope this helps.
Curtis
Sub main
oFolder = "C:\Temp\ThumbNails\"
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
'get current color scheme name
oColorScheme = ThisApplication.ActiveColorScheme.Name
'get current color scheme background type
oBackGroundType = ThisApplication.ColorSchemes.BackgroundType
'Change to Presentation (white background)
ThisApplication.ColorSchemes.Item("Presentation").Activate
'set to use one color background type
ThisApplication.ColorSchemes.BackgroundType = _
BackgroundTypeEnum.kOneColorBackgroundType
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
Dim oRefFile As FileDescriptor
	If oAsmDoc.AllReferencedDocuments.Count > 12 Then
		oRUSure = MessageBox.Show("This could take a while, continue?", "iLogic",MessageBoxButtons.YesNo)
		If oRUSure = vbNo Then
			Return 'exit rule
		End If
	End If
'save image for top level assembly
Call SaveImage(oDoc, oFolder)
For Each oDoc In oAsmDoc.AllReferencedDocuments
	ThisApplication.Documents.Open(oDoc.FullFileName, True)
	For Each oSketch In oDoc.ComponentDefinition​.Sketches
		oSketch.Visible = False
	Next
	'set work plane visibility
	For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
	oWorkPlane.Visible = False
	Next
	'set work axis visibility
	For Each oWorkAxis In oDoc.ComponentDefinition.WorkAxes
	oWorkAxis.Visible = False
	Next
	'set work point visibility
	For Each oWorkPoint In oDoc.ComponentDefinition.WorkPoints
	oWorkPoint.Visible = False
	Next
	oDoc.Close
Next
'Change back to original scheme
ThisApplication.ColorSchemes.Item(oColorScheme).Activate
'Change back to original back ground type
ThisApplication.ColorSchemes.BackgroundType = oBackGroundType
Process.Start(oFolder)
End Sub
Function SaveImage (oDoc As Document, oFolder As String)
	Dim m_Camera As Inventor.Camera
	Dim m_TO As Inventor.TransientObjects
	m_TO = ThisApplication.TransientObjects
	m_Camera = ThisApplication.ActiveView.Camera
	'm_Camera.Perspective = True
	m_Camera.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
	m_Camera.Fit
	m_Camera.ApplyWithoutTransition
	Dim m_CV As Inventor.View
	m_CV = ThisApplication.ActiveView
	Dim m_PrevMode As Integer
	Dim m_Disp3D As Boolean
	m_PrevMode = m_CV.DisplayMode
	m_Disp3D = ThisApplication.DisplayOptions.Show3DIndicator
	m_CV.DisplayMode = Inventor.DisplayModeEnum.kShadedWithEdgesRendering
	ThisApplication.DisplayOptions.Show3DIndicator = False
	m_CV.Update
	'split the string into an array using the dash
	sMyArray = oDoc.FullFileName.Split("\")
	i = UBound(sMyArray)
	oFileName = sMyArray(i)
	sMyArray = oFileName.Split(".")
	oFileName = sMyArray(0)
	If Not System.IO.Directory.Exists(oFolder ) Then
  	  System.IO.Directory.CreateDirectory(oFolder )
	End If
	'save image
	m_Camera.SaveAsBitmap( oFolder & oFileName &".bmp", 800, 600,)
End Function
Message 6 of 16
rcolon9E4ZX
Curtis,
Thank you for your replies. I already do something similar to this with Camera.SaveAsBitmap. I like the default background as the thumbnail background stored in the ipt file. Do you see the dark gray gradient background in my original post, and how this image has better quality? Both images in this post are stored thumbnails for ipt files. I want to know what is making some thumbnails have this dark gray background and increased quality. This is just something Inventor is doing because I have not set any properties to make this happen. Best case, I get some way to control this outcome.
For your first reply, I ran this code in VBA. It is essentially your posted sample code, but I do not change the color scheme.
Sub RefreshThumbnails()
Set oAsmDoc = ThisApplication.ActiveDocument
    ' open document
    ThisApplication.Documents.Open oDoc.FullFileName, True
    For Each oSketch In oDoc.ComponentDefinition.Sketches
    Next
    Next
    Next
    Next
    'set iproperty to use ISO view on save
    oDoc.SetThumbnailSaveOption _
    (ThumbnailSaveOptionEnum.kActiveComponentIsoViewOnSave)
    'save and close the file
    oDoc.Save
    oDoc.Close
Next
End Sub
The two images below from left to right are before and after running the code, respectively.
Before CodeBefore Code After CodeAfter Code
You can see that all the thumbs now have the default background. They also have reduced quality compared to those that had the dark gray background, like in my original post. At the very least, this is a way to force the same results across all images, so thank you for the reference.
This dark gray background anomaly has had me stumped since I first started this utility four years ago. It would be great if you can find out what is causing this, and I would gladly accept as solution.
Regards.
Rafael
Message 7 of 16
rcolon9E4ZX
Should have used @Curtis_Waguespack in the last post.
Message 8 of 16
Curtis_Waguespack
Hi @rcolon9E4ZX ,
I'm not sure why you'd see a different background, but the example I posted here shows how to get and set the color scheme to control this... it looks like the dark gray gradient is likely the "Presentation" scheme.
I hope this helps.
Curtis
Message 9 of 16
rcolon9E4ZX
Hi @Curtis_Waguespack ,
The dark gray background appears to be the default color scheme "Winter Night", but with the background type set to Gradient instead of 1 Color or Background Image. See image below.
"Winter Night" > Gradient"Winter Night" > Gradient
So now we know what properties are being changed. For some reason, capturing the thumbnail on save utilizes background type Gradient, but only some of the time. Maybe this be for items that are saved in the context of an assembly?
Rafael
Message 10 of 16
Curtis_Waguespack
Hi @rcolon9E4ZX
The code to use presentation and gradient is as follows, this would be per the application not per the file.
I hope this helps.
Curtis
'set to use gradient color background type
BackgroundTypeEnum.kGradientBackgroundType
Message 11 of 16
rcolon9E4ZX
I appreciate your replies. The only thing I am looking for in this thread is the root cause of why some thumbnails have the dark gray background along with increased quality. I now know the background type is changed to Gradient in some instances of saving thumbnail on save. I want to know why this is happening. Maybe this is some unintended result that can be corrected. Although untested, some hypotheses of mine are this happens when saving from context of an assembly, or it has something to do with Vault check-in or generating a DWF on check-in. Now that the change in properties is specifically understood, maybe someone knows where this takes place and why?
Regards.
Rafael
Message 12 of 16
Curtis_Waguespack
Hi @rcolon9E4ZX
As mentioned the color scheme can be set per application, not per file... (edit to add: but since the thumbnail is not getting set ) I suspect maybe your code it not hitting the correct files as it processes the assembly, or it is catching an error and skipping certain files, or something similar... But unless I've missed it, you've not included your entire code here so it's impossible to say for sure.
Does your VBA code include an "On Error Resume Next" line? If so, does commenting that out show you an error that might explain why some thumbnails are not getting updated?
Using the last code you posted and the last code I posted together I can change all of the thumbnail backgrounds to a given theme/color.
Below are those pieces of code combined in an iLogic rule, as well as a list box to choose the color scheme.
When I run this on an assembly and choose Forest I see the results shown in this image, I can choose a different scheme and see it change all of the thumbnails to that color scheme. I do not see any of them remaining as the dark gradient of Winter Night or any other anomalies.
I hope this helps.
Curtis
Dim MyStringValues = New String(){"Presentation", "Winter Night", "Forest", "Sky"}
oScheme = InputListBox("select", MyStringValues, "Presentation", "iLogic", "List")
'Change to color scheme
ThisApplication.ColorSchemes.Item(oScheme).Activate
    ' open document
    ThisApplication.Documents.Open (oDoc.FullFileName, True)
    Next
    Next
    Next
    Next
    oDoc.Save
    oDoc.Close
Next
Message 13 of 16
rcolon9E4ZX
This is not a question about my code. This is about what Inventor is doing internally when it saves a thumbnail on document save. Without running any VBA code, these anomalies occur during normal design use with Inventor. This is strictly something Inventor is doing on its own and I want to find out why. I know I can refresh the thumbnails with a specific background from an earlier reply. I am not asking for code samples to loop through and refresh. I just want the understanding of what is causing this anomaly during normal Inventor use.
Thanks.
Rafael
Message 14 of 16
Curtis_Waguespack
Hi @rcolon9E4ZX ,
As far as I know the thumbnail will only get updated when that file is saved, so again if it is not getting updated I would guess that it is not getting saved.
The examples I've provided were intended so that you could run them and see if you can get the anomalies to go away.
I can not reproduce the anomalies you mention with code or without.
But indeed I was under the impression you were looking to fix an issue with your VBA macro that leaves some thumbnails not updated.
I hope this helps.
Curtis
Message 15 of 16
rcolon9E4ZX
Thanks. Rest assured, I do not get any anomalies when running VBA code to refresh the thumbnails. This is just a head scratcher as to why Inventor changes the background type sometimes for saved thumbnails. I will find out why, and update this thread when I do.
Rafael
Message 16 of 16
Curtis_Waguespack
Hi @rcolon9E4ZX
I guess the only time I've seen the thumbnail colors change "magically" is when someone else saves the file on another machine/profile that is using a different color scheme. I guess I didn't think of this as an anomaly, but I guess it could seem that way if we're not aware that is going on?  So maybe the idea that someone else is saving the files using a different color scheme is something to rule out?
Which brings me to another thought, which might be that if you have Task Scheduler running a migration task during upgrades... it uses a "headless" Inventor that uses default settings ... this might update thumbnails as it saves? I'm not sure if that is true or not, but something that came to mind, so again maybe something to rule out?
I hope this helps.
Curtis
