VBA text to parameter
Jacques.Grobler
Jacques.Grobler
Hi all
I am trying to pass VBA userform TEXT to Inventor Parameters (NOT custom iProperties). Below is what I use to pass VALUES.
Sub param_Change(paramName As String, paramValue)
    'Get the Parameters Object. Assumes a Part or Assembly document as active
    Dim oParam As Parameter
    Set oParam = ThisApplication.ActiveDocument.ComponentDefinition.Parameters
    'Get the Parameter required
    Dim oParamName As Parameters
    Set oParamName = oParam.Item(paramName)
    'Change the equation of parameter
    oParamName.Expression = paramValue
    'Update document
    ThisApplication.ActiveDocument.Update
End Sub
How can I change this to pass TEXT and VALUES?
Jacques.Grobler
Anyone with advise out there please?
Jacques.Grobler
Ok, since there was no alternative options given, I have opted to move the TEXT to iProperties and only have VALUES under the parameters, this seems to have resolved my issue
MechMachineMan
From the API help:
Parameter.Expression
Property that allows you to get and set the equation associated with the parameter. Depending on the type of parameter, this property may not be writable.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
GeorgK
