VBA Skip warning when saving
pball
Mentor Mentor
Message 1 of 10
pball
I have a mass print script and I have it save then close the drawing after it's done printing each one. The problem is the script updates the mass properties and some times drawings just update when opened. So when it saves different "warnings" can pop up, which pause the script until the pop up is taken care of. The warnings are typically for saving other files like the ipt linked to a drawing or if the drawing was saved in an old version. Is there a way to just accept those while running a script so it does puase?
How I save and then close the drawing.
ThisApplication.ActiveEditDocument.Save
ThisApplication.ActiveEditDocument.Close True
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Userscript to edit forum links to jump to first unread post
Jump To First Post Userscript
Replies (9)
Message 2 of 10
YuhanZhang
SilentOperation can suppress Inventor warnings, maybe you want to use this.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 3 of 10
pball
Thanks. I played with this some and it seems to doing just what I need.
Message 4 of 10
hi,
would you mind sharing your code.
i have the same problem.
can i do it in vb within inventor?
thanks
inventor 2011
vault 2012
Message 5 of 10
jdkriek
ThisApplication.SilentOperation = True
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 6 of 10
pball
And one word of warning. Make sure to set it to False by the time the script finishes. I have some exit subs in the script I did and the setting stayed on after the script was done, if it was exited via the exit sub. So I found an event that fired when the script was done, whether it exited or completed and put set it back to false there.  Depending on what your script is like, you could just ignore what i've said.
Private Sub UserForm_Terminate()
    ThisApplication.SilentOperation = False
End Sub
Message 7 of 10
jdkriek
Good point, always set back to False 😉
Jonathan D. Kriek
Message 8 of 10
where can i do this code , inside inventor?
Message 9 of 10
jdkriek
Yes, you can use this in iLogic
You won't need the VBA script posted by pball for your situation.
Jonathan D. Kriek
Message 10 of 10
mrattray
You can set this as a tick box option in the iLogic rule editor as well.
Mike (not Matt) Rattray
