VBA Sheet Size doesnt work
I want to change the sheet size by macro.
But what ever I do, it changes only height... and width only after a second run of the macro.
How can I get the code run both size at once?
The code I use:
Dim oSheets As Sheet
Dim oDrawingDoc As DrawingDocument
Set oDrawingDoc = ThisApplication.ActiveDocument
Set oSheets = oDrawingDoc.ActiveSheet
oSheets.Size = DrawingSheetSizeEnum.kCustomDrawingSheetSize
oSheets.Height = 160
oSheets.Width = 250
frederic.vandenplas
SyntaxEditor Code Snippet
oSheets.Width = 250
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
ufff....
simply turn it Smiley Embarassed
thx
