VBA see if part is checked out from Vault
rcolon9E4ZX
rcolon9E4ZX
Hey guys,
I am developing a macro to generate the value of an iproperty based on others and some additional text for each child in an assembly. It works great, except I want to know if certain parts are checked out from the Vault when looping so I know to skip them. Currently, the program still makes edits to the checked out parts, even though it is read only and grayed out in Bill of Materials. Is there a line of code that can return true/false for if a part is checked out?
Many thanks in advance!
Rafael L. Colon
Abtex, Inc.
Based on past posts from actual ADSK programmers it does not look the API provides any methods to accomplish what you are requesting.
https://forums.autodesk.com/t5/inventor-customization/vault-access-through-inventor/m-p/5560858/high...
https://forums.autodesk.com/t5/inventor-customization/check-vault-status-via-vba/m-p/2795396/highlig...
Then again, I found this post from an ADSK programmer's blog about checking for read-only, using VB.net.
http://adndevblog.typepad.com/manufacturing/2012/05/checking-whether-a-inventor-document-is-read-onl...
Best of luck.
M.
rcolon9E4ZX
I found some code that returns if a file is read-only or not. This correlates to if a file is checked out by you or not. It works perfectly for what I am trying to do. When a part is checked in or checked out by another user, the local file for the part is read only. When a part is checked out by you, the file is not read-only. This can be seen when you right click on the part file -> Properties.
Here is the function that returns true or false if the file is read-only or not. No additional references are needed.
Private Function IsFileReadOnly(sFile) As Boolean
     ' Test to see if the Read-only attribute was assigned to the file.
    If GetAttr(sFile) And vbReadOnly Then
        IsFileReadOnly = True
    Else
       IsFileReadOnly = False
    End If
End Function
Hope this helps others.
Rafael L. Colon
Abtex Inc.
0x3FA5
Glad that I found your solution, works perfectly, thank you!
rcolon9E4ZX
Glad to hear it. Cheers.
