VBA Macro - OLE Database Connection Error
I am receiving the following message when trying a run a VBA macro in Inventor 2014.
Run-time error '3706':
Provider cannot be found.  It may not be properly installed.
It occurs at this line of code:
'Open connection
With oCN
    .Provider = "Microsoft.ACE.OLEDB.12.0"
    .ConnectionString = sConnection
    .Open
End With
I have a reference to the Microsoft ActiveX Data Objects 2.8 Library.  I believe that the problem is related to the reference because this macro worked fine in 2011.
I am running Windows 7 64 bit and MS Office 32 bit.  I have installed the Microsoft Access Database Engine 2010 Redistributable exe.  I have tried changing the reference to 2.7 and 6.0 but I still get the error.
Any ideas on how to fix this?
adam.nagy
Autodesk Support
Autodesk Support
I think you'll find this useful: http://forums.autodesk.com/t5/NET/32bit-AND-64bit-environment-database-connectivity/td-p/2925668
Cheers,
Adam Nagy
Autodesk Platform Services
ekinsb
You might also find this post useful.
http://modthemachine.typepad.com/my_weblog/2013/09/using-ms-access-databases-with-inventor-2014-vba....
Brian Ekins
Mod the Machine blog
Thanks for the info and explanations Adam and Brian.  Very helpful.
You may be able to install the exe via command line using -> AccessDatabaseEngine_x64.exe /passive
