VBA hWnd ListBox handle / scroll bar
In VBA (which doesn't have an hWnd property in ListBoxes)
I am trying to add a horizontal scrollbar to a listbox but need to get
the hwnd so I can set them. Anyone know how to get it?
or
anyone know how to add a horizontal scrollbar to a lisbox other than
using SendMessage?
In doing a bit more, I tried running the following code with a Spy trace
window running. The LB_SETHORIZONTALEXTENT message is getting to the
list box but doesn't add a scroll bar. Perhaps it isn't supported in
VBA but it seems like there should be a way.
Private Declare Function GetFocus Lib "user32" () As Long
Private Const LB_SETHORIZONTALEXTENT = &H194
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA"
(ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, lParam As
Any) As Long
Private Sub CommandButton1_Click()
Dim hwnd As Long
ListBox1.SetFocus
hwnd = GetFocus
Call SendMessageBynum(hwnd, LB_SETHORIZONTALEXTENT, 400, 0)
End Sub
> or
> using SendMessage?
Charles
Haven't tried it but does this help
http://www.developerfusion.com/show/1800/
and if not it looks like there are some others that might here
http://www.google.com/search?sourceid=navclient&q=vba+listbox+scrollbar
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Charles Bliss" wrote in message news:3EF863BB.4030101@cbliss.com...
> Any) As Long
> Dim hwnd As Long
> ListBox1.SetFocus
> hwnd = GetFocus
> End Sub
> > or
> > using SendMessage?
Charles, this is what I use in VB to force the horizontal to adjust to length of the info in the listbox.
Private Const LB_SETHORIZONTALEXTENT = &H194 Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hWnd As Long, _
ByVal wMsg As Long, ByVal wParam As Long, lParam As Any) As Long longest$ = List1.List(x) Rtn = SendMessage(List1.hWnd, LB_SETHORIZONTALEXTENT, Config.TextWidth(longest$) * 0.75 / 10, ByVal 0) (place this in a .bas file) Public longest$, Rtn As Long "Config.TextWidth" in this code is the string added to my listbox. The * 0.75/10 is basically a percentage over the length of the string that the scroll bar will create. Let me know it this helps. Mike
Charles,
Scrollbars in a VBA ListBox control are automatic. There are 2 ways you can go about it. First, change the column width to be greater than the width of the ListBox. Or second, if you do have more than 1 column changes the widths of the columns so that they are wider than the ListBox width. There you have it!
Joe
Thanks, that is exactly what I am looking for.
joesu wrote:
> Charles,
> Joe
