Keyboard Shortcuts
Keyboard Shortcuts
Keyboard Shortcuts
1. Can we assign keyboard shortcuts to menu and toolbar commands using API. Menus and toolbar are created thru API.
2. Can we run the inventor command that was last run
Any one can help in this regard. I will be thankful to him.
B.K
I think that for 1. you can assign a name that
includes an ampersand (&) character and Windows will automatically assign
the shortcut key to the particular menu and toolbar item, an example
follows:
Creating a new menu called "&File" gives you a
menu with a shortcut of F.
HTH, would be very surprised if you could "repeat"
the last Inventor command for item 2., unless anyone knows
differently?
1.
was last run
B.K
I want to assign some (CTRL + Key) combination for the short cut.
At this time I don't think it is possible. I have tried a couple of
different ways but not had any luck.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"mdtalib" wrote in message
news:f17112f.1@WebX.maYIadrTaRb...
