vba help!!
vba help!!
vba help!!
hi..
what is the code in selecting a sketch block from the browser in vba?
i only need to get the name of the block selected..
    Enjoy mate.. Here is the code...
    Give Some Kudos and accept as Solution Smiley Happy
Sub SketchSel()
Dim prtdoc As PartDocument
Set prtdoc = ThisApplication.ActiveDocument
Dim prtdef As PartComponentDefinition
Set prtdef = prtdoc.ComponentDefinition
Dim sk As PlanarSketches
Set sk = prtdef.Sketches
Dim osk As PlanarSketch
For i = 1 To prtdef.Sketches.count
   Set osk = prtdef.Sketches(i)
    For j = 1 To osk.SketchBlocks.count
        If InStr(osk.SketchBlocks(j).Name, "Steel") Then
            prtdoc.SelectSet.Select prtdoc.ComponentDefinition.Sketches(i).SketchBlocks(j)
        End If
    Next
Next
End Sub
this is in red:
am i correct to say that the code is predefining the blocks name as whatever (eg. steel)??
what i would like to do is select the block from the browser and not hardcode it .is it doable?
thanks..Smiley Indifferent
Check my answers in RED
Make sure you got a part document as opend file in Inventor.
Yes..  the code is looking for blocks with name(string) contains "Steel".
You need to have a find or search function where you can enter name of block to be selected and code will highlight that block
