VBA excel on date form Inventor... Vlookup keep fail.. Why?
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 1
I have this code in Excel VBA
Dim rownr
Dim TotalUnit As Integer
Dim Total As Integer
Dim countup As Integer
rownr = 2
 Do Until Cells(rownr, 36).Value = ""
 TotalUnit = 0
 Total = 0
 'main item for this count
 TotalUnit = (Len(Cells(rownr, 36)) - 1)
 Total = Cells(rownr, 37)
 Cells(rownr, 38).Value = Total
 ' add secondar unit
 currentItem = 1
  Do Until TotalUnit = 0
  If Right(left((Cells(rownr, 36).Value), (TotalUnit + 1)), 1) = "." Then
    Multiunit = 0
    Multiunit = Application.WorksheetFunction.VLookup(left(Cells(rownr, 36).Value, TotalUnit), Range("A:AL"), 37, False)
 If Multiunit = 0 Then
  Multiunit = 1
    Total = Total * Multiunit
  Else
  End If '
 TotalUnit = TotalUnit - 1
  Loop
  rownr = rownr + 1
 Loop
End Sub
 The Code give me this
But I was surpose to get this
 it seems that the Vloopup fail for some reason ... the thing is that the same code have work in a Test excel.. back then it seems that it wanted to have AJ as String in formating in excel and AK as number to work ... one other problem it have that the code need to be under the Sheet... and not the workbook folder ... I have done both as far as I know is the final doc.. that I try to creat.. .. but it seems to not work no matter what I do.  Any idear why and how to fix it?
Replies (0)
