Action recognition macro
npdedyukhin
Observer Observer
npdedyukhin
Observer
Observer
Good day, gentlemen!
Please tell me, I have a desire to understand one interesting question:
How to refer to the first of the actions in the Action tree? (action is highlighted in red in the screenshot)
I want the system to recognize this action and write the name of this action to a variable, be it Extrusion or Swipe or something else.
For example, I want to see: x_1 = Extrusion.
How to refer to the sketch from the first activity?
How to recognize the characteristics of this sketch? What is its geometric shape?
So that, for example, the macro then performs the same sketch but in a different location.
JelteDeJong
For the first part of your question. This iLogic rule will create a parameter with the first feature type.
Dim doc As PartDocument = ThisDoc.Document
Dim def As PartComponentDefinition = doc.ComponentDefinition
Dim firstFeature = def.Features.Item(1)
Dim typeName = CType(firstFeature.Type, ObjectTypeEnum).ToString()
typeName = typeName.Substring(1, typeName.Length - 7)
Try
    def.Parameters.Item("x_1").Value = typeName
Catch ex As Exception
    def.Parameters.UserParameters.AddByValue("x_1", typeName, "text")
End Try
For the rest, it's unclear to me what you try to accomplish. Do you want to copy the sketch someplace?
Jelte de Jong
Blog: hjalte.nl - github.com
npdedyukhin
Observer
Observer
Hello!
Thank you for your help in my endeavor.
I answer your question:
When creating parts of the same type, a situation may arise where it is necessary to repeat the same actions. It would be convenient to copy part of the part building steps from an existing part using a macro. This is an experiment. It's interesting what will come of this.
