VBA Dialog boxes opening on wrong monitor
pball
Mentor Mentor
pball
I received dual monitors a while ago and I've noticed an annoying issue with VBA dialogs. No matter which screen I have inventor open on all but one of my dialog boxes opens to the far left side of my right monitor. This is quite annoying as I normally have to drag the dialog bad to a better spot.
All of my dialogs have the "Center Owner" for the start up position selected. I can't explain why one scripts dialog box appeared centered and the rest don't.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
xiaodong_liang
Autodesk Support
Autodesk Support
I have not much experience with VBA dialog, but if you could provide a test demo which has a working dialog and a not-working dialog, I can try to find if anything is different.
