VBA ComboBox Populated with multiple classes
Hi everyone
This is not really an Autodesk question, but it is something I'd like to integrate into Inventor so I am going to ask it anyway...
I am trying to create, on a userform, 2 comboboxes for steel sections.
Box 1 will be used to select between FB, Angles, Channels etc. And then box 2 will be the different available sizes for what ever sections is selected.
Box 1 list is populated using .AddItem method and Box 2 is populated using a class list.
Getting to switch between classes for Box 2 is fairly simple, and I am able to retrieve the correct values from my classes for each connected class.
However the problem comes in after I have done 2 or 3 selections, all of a sudden the returned values no longer update.
I have gone through my code and I cannot see where the problem occurs.
Below is my code:
Option Explicit Dim WithEvents objFB As cls_Section_FB Dim WithEvents objL As cls_Section_L Dim WithEvents objC As cls_Section_C Private Sub UserForm_Initialize() With cmb_Sections .AddItem "FB" .AddItem "C" .AddItem "L" End With End Sub Private Sub cmb_Sections_Change() cmbFlange.Clear If cmb_Sections = "FB" Then Set objFB = New cls_Section_FB Set objFB.ListControl = Me.cmbFlange Set objFB.m_cmb_Section = Me.cmbFlange ElseIf cmb_Sections = "L" Then Set objL = New cls_Section_L Set objL.ListControl = Me.cmbFlange Set objL.m_cmb_Section = Me.cmbFlange ElseIf cmb_Sections = "C" Then Set objC = New cls_Section_C Set objC.ListControl = Me.cmbFlange Set objC.m_cmb_Section = Me.cmbFlange End If End Sub Private Sub objL_SectionCalc() With objL lblHeight = .section_Height lblR1 = .section_R1 lblR2 = .section_R2 lblTF = .section_TFlange lblTW = .section_TWeb lblWidth = .section_Width lblName = .section_Name End With End Sub Private Sub objFB_SectionCalc() With objFB lblHeight = .section_Height lblWidth = .section_Width lblName = .section_Name lblR1 = 0 lblR2 = 0 lblTF = 0 lblTW = 0 End With End Sub Private Sub objC_SectionCalc() With objC lblHeight = .section_Height lblR1 = .section_R1 lblR2 = .section_R2 lblTF = .section_TFlange lblTW = .section_TWeb lblWidth = .section_Width lblName = .section_Name End With End Sub
