VBA ComboBox Populated with multiple classes
Jacques.Grobler
Jacques.Grobler
Hi everyone
This is not really an Autodesk question, but it is something I'd like to integrate into Inventor so I am going to ask it anyway...
I am trying to create, on a userform, 2 comboboxes for steel sections.
Box 1 will be used to select between FB, Angles, Channels etc. And then box 2 will be the different available sizes for what ever sections is selected.
Box 1 list is populated using .AddItem method and Box 2 is populated using a class list.
Getting to switch between classes for Box 2 is fairly simple, and I am able to retrieve the correct values from my classes for each connected class.
However the problem comes in after I have done 2 or 3 selections, all of a sudden the returned values no longer update.
I have gone through my code and I cannot see where the problem occurs.
Below is my code:
Option Explicit
Dim WithEvents objFB As cls_Section_FB
Dim WithEvents objL As cls_Section_L
Dim WithEvents objC As cls_Section_C
Private Sub UserForm_Initialize()
    With cmb_Sections
        .AddItem "FB"
        .AddItem "C"
        .AddItem "L"
    End With
End Sub
Private Sub cmb_Sections_Change()
    cmbFlange.Clear
    If cmb_Sections = "FB" Then
        Set objFB = New cls_Section_FB
        Set objFB.ListControl = Me.cmbFlange
        Set objFB.m_cmb_Section = Me.cmbFlange
    ElseIf cmb_Sections = "L" Then
        Set objL = New cls_Section_L
        Set objL.ListControl = Me.cmbFlange
        Set objL.m_cmb_Section = Me.cmbFlange
    ElseIf cmb_Sections = "C" Then
        Set objC = New cls_Section_C
        Set objC.ListControl = Me.cmbFlange
        Set objC.m_cmb_Section = Me.cmbFlange
    End If
End Sub
Private Sub objL_SectionCalc()
    With objL
         lblHeight = .section_Height
         lblR1 = .section_R1
         lblR2 = .section_R2
         lblTF = .section_TFlange
         lblTW = .section_TWeb
         lblWidth = .section_Width
         lblName = .section_Name
    End With
End Sub
Private Sub objFB_SectionCalc()
    With objFB
        lblR1 = 0
        lblR2 = 0
        lblTF = 0
        lblTW = 0
    End With
End Sub
Private Sub objC_SectionCalc()
    With objC
         lblR1 = .section_R1
         lblR2 = .section_R2
    End With
End Sub
Jacques.Grobler
Any advice on this one pls?
Jacques.Grobler
Help pls
