VBA code to get and set the category design tracking iProperty metadata.
tom.prichard
tom.prichard
My code in an abbreviated form looks like this,,,
Set oDoc = ThisApplication.ActiveDocument
Set oPropertySets = oDoc.PropertySets
Set oDesignProperty = oPropertySets.Item("Design Tracking Properties")
'Set oProp = oDesignProperty.Item("Category") 'No-such iProperty
Set oProp = oDesignProperty.Item("Categories") '(Saves but does not display in iProps dialogue)
Will someone please let me know why the 'category' and/or 'categories' prop. does not populate the iProperties when set by VBA? Thank you for any assistance you can provide.
sundars
Hi @tom.prichard
The  "Document Summary" property has a category item in it. Is that what you want?
Set oDesignProperty = oPropertySets.Item("Document Summary Information")
-shiva
Shiva Sundaram
Inventor Development
tom.prichard
I was using this,,,
'Set oDocumentProperty = oPropertySets.Item("Inventor Document Summary Information")
,,,not,,,
Set oDocumentProperty = oPropertySets.Item("Document Summary Information")
,,,because of test output from this,,,,
For Each oUserProperty oPropertySets
   'MsgBox (oDocumentProperty.Name)
   Debug.Print (oUserProperty.Name)
Next oUserProperty
YOU ARE RIGHT,,,, solved,
johnsonshiue
Hi Tom,
"Categories" seems to be a hidden property. Here is what I got from Inventor API help.
kCategoriesDesignTrackingProperties 56 Categories: String (VT_BSTR), Read Only, No UI, XML string providing the complete categorization of this model, along with the mappings of the Category Parameters to parameters within this Document.
Many thanks!
Software Test Engineer
