Problem accessing Part files's iLogic rule from an iLogic rule in Assembly file.
Dear all,
I have an Assembly file which consists of a part file containing 2 rules. When I try to access a rule from Assembly files using,
iLogicVB.RunRule("PartFile_Name:1","Rule_1")
Suprisingly this error shows up.
Unable to cast COM object of type 'System.__ComObject' to interface type 'Inventor.PartFeatures'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{DA33F1A5-7C3F-11D3-B794-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
The Rule_1 in part file changes the sweep feature. I would like to change the paramteres used in the sweep feature from assembly files iLogic rule.
can any one please help me!
Thanks a lot in advance.
Yatish.
FINET_Laurent
Morning,
I have a similar issue not long ago..
Here is the correct way :
iLogicVb.Automation.RunRule("Document", "RuleName")
You'll have to declare the document tho, something like this maybe :
Dim oDoc As Document
For Each oDoc In ThisApplication.Documents.VisibleDocuments
	If oDoc.DisplayName = "Vertical baffle 1.iam" Then
		iLogicVb.Automation.RunRule(oDoc, "RuleName")
Next
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Hallo @FINET_Laurent  Thank you for the solution.
The problem still arises for one of the two rules.
Rule_1:
MessageBox.Show("Test_Message","Title")
Rule_2:
'Do Something
Dim
oSweep As SweepFeature = oCompDef.Features.SweepFeatures.AddUsingPath(oProfile, oPath, kJoinOperation
'Do Something
I've used this code in a rule in Assembly file:
	If oDoc.DisplayName = "Part1.ipt" Then
		iLogicVb.Automation.RunRule(oDoc, "Rule_1")
		iLogicVb.Automation.RunRule(oDoc, "Rule_2")
Next
 The Error still shows up at the Rule_2.
Yatish.
FINET_Laurent
This may be about the rule 2 itself.
Can you post the full code for that rule ? (If not confidential)
FINET L.
Hey @FINET_Laurent  Here is the code for rule#2. I have changed the names for some reasons.
'Rule#2
Dim
oFeatures As PartFeatures oFeatures = ThisApplication.ActiveDocument.ComponentDefinition.Features
If Feature.IsActive("Sweep") = True Then oFeatures("Sweep").Delete End If Dim oPartDoc As PartDocument = ThisDoc.Document Dim oCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition ' Create a profile. Dim oSketch1 As Sketch = oCompDef.Sketches.Item("Sketch_2") Dim oProfile As Profile = oSketch1.Profiles.AddForSolid ' Create a path. Dim oSketch2 As Sketch = oCompDef.Sketches.Item("Sketch_1") Dim oPath As Path = oCompDef.Features.CreatePath(oSketch2.SketchLines(1)) ' Create the sweep feature. Dim oSweep As SweepFeature = oCompDef.Features.SweepFeatures.AddUsingPath(oProfile, oPath, kJoinOperation) oSweep.Name = "Sweep"
Yatish.
FINET_Laurent
I think there is a mistake aroud this :
I think The active document is the assembly document you are  lauching the rules from.
Maybe you need to activate the part document first (from the assembly) :
	If oDoc.DisplayName = "part2.ipt" Then
		oDoc.Activate
		iLogicVb.Automation.RunRule(oDoc, "Test")
		'iLogicVb.Automation.RunRule(oDoc, "Rule_2")
Next
 The oDoc.Activate set the document to the active document.
FINET L.
@FINET_Laurent  Hey, Thank you so much. Yes. The oDoc.Activate is the fix.
