Message 1 of 1
[VBA] Add new library to project file and (some weirdness) getting it active
First of all, i think i've got it to work, but is was a journey.
So i'm adding and new material and appearance libraries to multiple project files. This seemed pretty straightforward, but it ended up challenging. It was the setting active of a library, that got weird.
Manually, no problem:
But doing the same thing from VBA, this happened:
And when asked for the active library, the old version was returned.
The solution for this weird behavior was -apparently- to delete the active library, then add the new library and finally re-adding the deleted one:
Private Sub FixProject()
Dim oProject As DesignProject
Set oProject = ThisApplication.DesignProjectManager.DesignProjects.AddExisting("C:\Temp\Temp\Test_project.ipj")
Dim newLibPath As String
newLibPath = "I:\Inventor_Data\Materials\Test_library_new.adsklib"
Dim newLib As ProjectAssetLibrary
Dim oLib As ProjectAssetLibrary
Dim activeLib As ProjectAssetLibrary
Dim activeLibPath As String
'MaterialLibraries
'note active library, to delete and add back later
Set activeLib = oProject.ActiveMaterialLibrary
activeLibPath = activeLib.LibraryFilename
'check if new library already exists
For Each oLib In oProject.MaterialLibraries
If StrComp(oLib.LibraryFilename, newLibPath, vbTextCompare) = 0 Then
Set newLib = oLib
Exit For
Next oLib
'not found, add
If newLib Is Nothing Then Set newLib = oProject.MaterialLibraries.Add(newLibPath)
'delete active
If Not StrComp(activeLib.LibraryFilename, newLib.LibraryFilename, vbTextCompare) = 0 Then activeLib.Delete
'set active
Call newLib.Activate
're-add deleted
If Not StrComp(activeLib.LibraryFilename, activeLibPath, vbTextCompare) = 0 Then _
Call oProject.MaterialLibraries.Add(activeLibPath)
'reset
Set newLib = Nothing
Set oLib = Nothing
Set activeLib = Nothing
activeLibPath = ""
'AppearanceLibraries
Set activeLib = oProject.ActiveAppearanceLibrary
For Each oLib In oProject.AppearanceLibraries
Set newLib = oLib
Exit For
Next oLib
'not found, add
If newLib Is Nothing Then Set newLib = oProject.AppearanceLibraries.Add(newLibPath)
'delete active
'set active
're-add deleted
End Sub
