VB.net sort and List all parameters to checked listbox
j.romo
j.romo
Hello again,
Is there a way to get all the angular  parameters into a Checked listbox to select them?
I have no Idea how to sort them and to populate the listbox.
Any help would be apreciated
something like this
S.Hørup
How do you intent the form should work - what are the workflow for the user?
I can't figure out why you need the check boxes in the form you have shown.
How I would approach it:
- Loop through all parameters
-- If parameter = angle parameter then add parameter.name to list
Sorting can usually be done in the properties for the list
j.romo
Thanks for the aproach, I will try to make the Loop  (but I am not as skilled yet) and I have to investigate how to fill the Check boxes.
I would like to select in the box the parameters to change, i am making a simple unfolding Flower for rollforming
In the chkBox I would like to have the angle dimensions so I can select some of them and apply angle changes in diferent sequences.
right now I cant even populate a simple textbox when a domension is selected 😞
S.Hørup
Is it not an option to select just one angle from the list (no multi-select) and and update tha value - Then select the next angle and update that one?
or are you going to change the selected angles with the same amount, but in turns?
Sorry, I do not exactly understand what you are aming for.
But here are some code to get you started:
It loops through all parameters in the part, and adds all angle parameters to the checklistbox
 Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        Dim invApp = g_inventorApplication
        Dim oDoc As PartDocument = invApp.ActiveDocument
        Dim oCompDef As ComponentDefinition = oDoc.ComponentDefinition
        Dim oParams As Parameters = oCompDef.Parameters
        'Dim oUserParams As UserParameters = oCompDef.Parameters.UserParameters
        Dim uom As UnitsOfMeasure = oDoc.UnitsOfMeasure
        For Each oParam As Parameter In oParams
            If uom.CompatibleUnits(oParam.Expression, oParam.Units, "1", "deg") Then
                'The parameter is an angle parameter
                CheckedListBox1.Items.Add(oParam.Name)
            End If
        Next
    End Sub
j.romo
The idea is to select 1 or more angles and change them at the same time.
The code worked like a charm, even I could modify it to update as you add more angles or change the angle name parameter.
the goal is to meke somethin like the pic below
create a new WP and Sketch and project the resulting geometry with its changes
to get a unfolding sequence of the main profile.
