VB.net selecting sketch point problems => System.__Comobject
MICHAEL.JONES.AMCE
MICHAEL.JONES.AMCE
Attempting to transition away from VBA and iLogic to a VB.net addin.
Using the Nifty Add-in Template by Mr. Ekins.
Having difficulties casting my selected object into a sketchpoint.
Namespace UCSPlacementApp
    Public Module SelectPoint
        Private WithEvents m_intereaction As Inventor.InteractionEvents
        Private WithEvents m_mouse As Inventor.MouseEvents
        Public Function SelectPoint() As Inventor.SketchPoint
            'Dim MyPointSelection As ClsSelectPoint
            'If MyPointSelection Is Nothing Then
            '    MyPointSelection = New ClsSelectPoint
            'End If
            If g_DebugOn Then
                MsgBox("Getting Point From User", vbOK, "AMA ROUTINE")
            Dim tempPoint As SketchPoint
            Try
                tempPoint = g_InventorApplication.CommandManager.Pick(SelectionFilterEnum.kSketchPointFilter, "Select UCS origin point.")
                'tempPoint = MyPointSelection.GetPoint
                If tempPoint Is Nothing Then
                    Return Nothing
            Catch ex As Exception
                MsgBox("Error while having user select the origin point!" & vbCr & vbCr & ex.Message, vbOK, g_AMA_error_title)
                ' CatchErrorcatch:
                Debug.Print(ex.Message)
            End Try
            Try
                tempPoint = DirectCast(tempPoint, SketchPoint)
            Catch
                MsgBox("Error casting selected point!", g_AMA_error_title)
                Exit Function
            End Try
            If Not (tempPoint Is Nothing) Then
                myPoint = tempPoint.Geometry
            Dim oSketch As PlanarSketch = myPoint.Parent
            Dim my2DPoint As Point2d = myPoint.Geometry
            Dim my3DPoint As Point = oSketch.SketchToModelSpace(my2DPoint)
            'tempPoint = oSketch.SketchToModelSpace(my2DPoint)
            If g_DebugOn Then
                PrintXYZ(tempPoint)
            'm_intereaction.Stop()
            ' ENABLE THE LISTBOX FOR THE ANGLE
            g_UCSForm.lbAngleInput.Enabled = True
            g_UCSForm.lbAngleInput.Visible = True
            g_UCSForm.lbAngleInput.SelectedItem = ((g_UCSForm.lbAngleInput.Items.Count - 1) / 2) + 1
            Return oSketch.SketchToModelSpace(my2DPoint)
        End Function
Thank you in advance for your time in this matter.
M.
WCrihfield
Why are you using DirectCast to convert the variable's (tempPoint) type to be SketchPoint, when you have already defined that variable to be the type SketchPoint above that point, and used a selection filter to ensure that's the type of object you are selecting?  It seems unnecessary.
Wesley Crihfield
(Not an Autodesk Employee)
MICHAEL.JONES.AMCE
Not sure, that's why I'm asking the question.
We get the error dialog shown above and below, with or without the cast.
WCrihfield
I would eliminate the whole Try...Catch...End Try block around the DirectCast call, because it is not necessary.
I would eliminate the next If Not (tempPoint Is Nothing)....Then..End If block of code too, because you have already checked if 'tempPoint' is Nothing, so it has no use, and hides the variable 'myPoint' first appearance within that block.  Then I would just not use that 'myPoint' variable, because you don't need to.
{If its value would have been set successfully, it would have been assigned a Point2d object to it, and therefore set the variable's type (late binding) to Point2d.  Then below, where you were attempting to get a PlanarSketch from 'myPoint.Parent' would have thrown an error, because a Point2d doesn't have a Parent property.}
Just use the 'tempPoint' variable in place of the 'myPoint' variable in those next two lines, where you are setting the values of the 'oSketch' and 'my2DPoint' variables.  It is already the right object type and correct reference for use in those two places.
Then, there is also the question of what object type you are wanting your Function to return.  The Function's definition line, is stating that it is expecting to return a SketchPoint, but near the bottom of your code, you are using a 'Return' line, that is attempting to return a Point object.  One of the two will have to change.
Wesley Crihfield
MICHAEL.JONES.AMCE
Appreciate the assistance and advise.
Cleaned up my messy code and validated what exactly is needed.
Screencast of the testing framework/app:
https://knowledge.autodesk.com/community/screencast/09001ec5-9381-4e80-939f-321503383036
Thank you again.
