Vb.Net "Addin" exit Sub on Closing a Part Document
isocam
isocam
Can anybody help????
I have the following "Sub" in a Vb.Net "Addin".....
       Private Sub m_applicationEvents_OnCloseDocument(DocumentObject As Inventor._Document, FullDocumentName As String, BeforeOrAfter As Inventor.EventTimingEnum, Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles m_applicationEvents.OnCloseDocument
            If BeforeOrAfter = EventTimingEnum.kBefore Then
                If m_inventorApplication.ActiveDocument.DocumentType = DocumentTypeEnum.kPartDocumentObject Or DocumentTypeEnum.kAssemblyDocumentObject Or DocumentTypeEnum.kDrawingDocumentObject Then
                    Try
                        Dim invVBAProject As InventorVBAProject = m_inventorApplication.VBAProjects.Item(1)
                        Dim invModule As InventorVBAComponent = invVBAProject.InventorVBAComponents.Item("Module04")
                        Dim invSub As InventorVBAMember = invModule.InventorVBAMembers.Item("OnClose")
                        invSub.Execute()
                        ' DO YOU WANT TO CLOSE THE PART YES/NO?
                        ' IF I SELECT "NO" - DO NOT CLOSE THE PART
                    Catch ex As Exception
                    End Try
                End If
            End If
        End Sub
All I want to do (For a test only!!!) is to add a MsgBox saying "Do you really want to close Part Yes/No"
Selecting "Yes" will work OK because there will be no change to the above code!
If I select "No" I want to exit the addin so that the current part does not close.
Does anybody know how I can do this?
Many thans in advance!
Darren
GeorgK
Hello Darren,
Select Case MsgBox("DO YOU WANT TO CLOSE THE PART?", vbQuestion or vbYesNo, "Title")
Case vbYes
    ' Yes
     'Your code
Case vbNo
    ' No
    'Your code
End Select
Georg
EelcoWiggers
Hello Darren,
You can use this code:
If (MessageBox.Show("Question", "Caption", MessageBoxButtons.YesNo, _
       MessageBoxIcon.Question) = Windows.Forms.DialogResult.Yes) Then
    'Your Code if Yes
Else
    'Your Code if No
End If
Eelco
ekinsb
If you want to stop the document from closing you can set the value of the HandlingCode argument to kEventCanceled within your OnCloseDocument handler.  That will abort the close.
Brian Ekins
Inventor and Fusion 360 API Expert
Mod the Machine blog
