vb.net put component occurence into class
snappyjazz
snappyjazz
I am setting up a class that will:
  • hold the component occurrence
  • get the name of the comp occ
  • define a position quadrant from the matrix of the comp occ
  • define the direction the part is facing from the matrix of the comp occ
I can pass a component occurrence to the class via "Public Sub New" however I cannot pass that occurrence to a variable which can be read to make the above list. Is a component occurrence an unacceptable data type to be handled by a class?
    Public Sub IntGussetsEconToStack()
        'get inventor session
        Dim InvApp As Inv.Application = SysInter.Marshal.GetActiveObject("Inventor.Application")
        Dim InvDoc As Inv.AssemblyDocument = InvApp.ActiveDocument
#Region "get the Interior Stiff occurances"
        Console.Write(vbNewLine & vbNewLine)
        'Dim ExistingIntFBGussList As New List(Of Inv.ComponentOccurrence)
        Dim ExistingIntFBGussList As New List(Of Gusset)
        Dim ExistingIntLRGussList As New List(Of Inv.ComponentOccurrence)
        For Each OccItem As Inv.ComponentOccurrence In InvDoc.ComponentDefinition.Occurrences
            If OccItem.Name.Contains("GUSSET,INT,F&B") Then
                Dim Gusset As New Gusset(OccItem)
                ExistingIntFBGussList.Add(Gusset)
            End If
        Next
        Console.WriteLine("Existing F/B gussets: " & ExistingIntFBGussList.Count & vbNewLine & "Existing L/R gussets: " & ExistingIntLRGussList.Count & vbNewLine & vbNewLine)
#End Region
    End Sub
#Region "Gusset Class"
    Public Class Gusset
        Protected InvApp As Inv.Application = SysInter.Marshal.GetActiveObject("Inventor.Application")
        Protected InvDoc As Inv.AssemblyDocument = InvApp.ActiveDocument
        Protected TransGeo As Inv.TransientGeometry = InvApp.TransientGeometry
        Protected _Occ As Inv.ComponentOccurrence
        Protected GussTrans As Inv.Vector = _Occ.Transformation.Translation
        Protected UoM As Inv.UnitsOfMeasure = InvDoc.UnitsOfMeasure
        Protected _Name As String = _Occ.Name
        'Protected _Location As Inv.Point = TransGeo.CreatePoint(UoM.ConvertUnits(GussTrans.X, Inv.UnitsTypeEnum.kCentimeterLengthUnits, Inv.UnitsTypeEnum.kInchLengthUnits), UoM.ConvertUnits(GussTrans.Y, Inv.UnitsTypeEnum.kCentimeterLengthUnits, Inv.UnitsTypeEnum.kInchLengthUnits), UoM.ConvertUnits(GussTrans.Z, Inv.UnitsTypeEnum.kCentimeterLengthUnits, Inv.UnitsTypeEnum.kInchLengthUnits))
        Protected _Quadrant As Quad
        Protected _Direction As Direction
        Public Sub New(CompOcc As Inv.ComponentOccurrence)
            _Occ = CompOcc
        End Sub
        Public Enum Quad
            FR
            RR
            FL
            RL
        End Enum
        Private Sub AssignQuad()
            Select Case True
                Case _Location.X >= 0 AndAlso _Location.Z > 0
                    _Quadrant = Quad.FL
                Case _Location.X >= 0 AndAlso _Location.Z < 0
                    _Quadrant = Quad.RR
                Case _Location.X < 0 AndAlso _Location.Z > 0
                    _Quadrant = Quad.FR
                Case _Location.X < 0 AndAlso _Location.Z < 0
                    _Quadrant = Quad.RL
            End Select
        End Sub
        Public ReadOnly Property Name As String
            Get
                Return _Name
            End Get
        End Property
        Public ReadOnly Property Location As Inv.Point
            Get
                Return _Location
            End Get
        End Property
        Public ReadOnly Property Quadrant As String
            Get
                Return _Quadrant
            End Get
        End Property
        Public Enum Direction
            FRONT
            BACK
            LEFT
            RIGHT
        End Enum
        Private Sub AssignDirection()
            Select Case True
                Case GussTrans.Cell(1, 4) > 0 AndAlso GussTrans.Cell(3, 4) > 0
                    _Direction = Direction.BACK
                Case GussTrans.Cell(1, 4) > 0 AndAlso GussTrans.Cell(3, 4) < 0
                    _Direction = Direction.FRONT
                Case GussTrans.Cell(1, 4) < 0 AndAlso GussTrans.Cell(3, 4) > 0
                Case GussTrans.Cell(1, 4) < 0 AndAlso GussTrans.Cell(3, 4) < 0
            End Select
        End Sub
    End Class
#End Region
I don't see where you are trying to Add the Occurrence variable to a list, but you should be able to to what you want with the Gusset._Occ.
I believe the issue is you have defined it as Protected, try defining it as Public. Protected means it can only be used in your Gusset class or any derived from it.
snappyjazz
@Anonymous
Thanks for responding. I switched the _Occ variable to Public and it still comes up empty.
Oh I see. I think the issue is that it's trying to set your class variables before it runs your Sub New. So you're going to want to put anything that uses _Occ in Sub New or where ever you actually us the variable. For example,
            _Occ = CompOcc
            GussTrans = _Occ.Transformation.Translation
        End Sub
            Select Case True
            End Select
        End Sub
snappyjazz
That's what I was missing. Thank you!
