VB.NET opening .SAT file as a Multi-body part instead of and Assembly
I'm trying to open a .SAT file using the code below, and its opening as an Assembly.
Dim InvApp As Inventor.Application
InvApp.Documents.Open(C:\test.sat, True)
When I manually open the .SAT file I get prompted to create as and "Assembly", "Multi-body part", and "Composite feature part". Is there a way to select the multi-body part option programmatically?
moveworkforward
Hi @Anonymous
Try this:
Sub ImportSAT()
    Dim oSat As TranslatorAddIn
    oSat = ThisApplication.ApplicationAddIns.ItemById("{89162634-02B6-11D5-8E80-0010B541CD80}")
    Dim oDM As DataMedium
    oDM = ThisApplication.TransientObjects.CreateDataMedium
    Dim oContext As TranslationContext
    oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kDataDropIOMechanism
    Dim oOptions As NameValueMap
    oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    oDM.MediumType = kFileNameMedium
    oDM.FileName = "C:\test.sat"
    ' Import SAT as a single part with multiple solid bodies
    oOptions.Add ("ImportAASP", True)
    oOptions.Add ("ImportAASPIndex", 0)
    Dim oDoc As PartDocument
    oDoc = ThisApplication.Documents.Add(kPartDocumentObject)
    Call oSat.Open(oDM, oContext, oOptions, oDoc)
End Sub
Below is the list of all available Open Options for SAT translator:
SaveLocationIndex = 0
ComponentDestFolder = ''"
AssemDestFolder = ""
SaveAssemSeperateFolder = False
AddFilenamePrefix = False
FilenamePrefix =
AddFilenameSuffix = False
FilenameSuffix =
EmbedInDocument = True
SaveToDisk = False
ImportSolid = True
ImportSurface = True
ImportWire = True
ImportValidationProperties = False
CreateIFO = False
ImportAASP = False
ImportAASPIndex = 0
CreateSurfIndex = 1
GroupName =
GroupNameIndex = 0
ImportUnit = 0
CheckDuringLoad = False
AutoStitchAndPromote = True
AdvanceHealing = False
EdgeSplitAndMergeDisabled = False
FaceSplitAndMergeDisabled = False
Link Visibility = True
DefaultPartnames = True
