VB.Net - How do I determine whether a Positional Representation is failing?
I'm looping trough positional representations in a assembly and I would like to determine if one of them is failing.
Can some one give me a nice hint on a solution?
Thanks.
skyngu
loop through all positional representations and activate each. fail = error
see if it helps.
on error resume next
if err then
err clear
counter = counter +1
end if
Autodesk Inventor Professional 2019
Thanks for the obvious solution!
Will try that.
Some times you just don't see the simple solutions Smiley Indifferent
Well, I tried the solution but this will not give me the right result.
This is because the positional representation does activate correctly but has errors.
So now the question is more like: How do I determine whether a positional representation has errors?
Well, I did find a half solution and don't know whether there is a better one.
For now, I activate each positional representation and then search for failing constraints.
When one fails, I know the positional representation also fails.
Vladimir.Ananyev
There is no API for this task. Your workaround is a good idea.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
