VB.net get iProperties from selected part/assembly in drawing
Hi there,
I'm trying to access some User definied iProperties of a selected part/assembly within a drawing view. I just get part as a kGenericObject therefore I can't access the properties.
Anyone there who can help me??
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        'Test
        If _invApp.Documents.Count = 0 Then
            MsgBox("Need to open an Assembly document")
            Return
        End If
        If _invApp.ActiveDocument.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
            MsgBox("Es muss eine Z-Ableitung aktiv sein.")
            Return
        End If
        Dim drawDoc As DrawingDocument
        drawDoc = _invApp.ActiveDocument
        If drawDoc.SelectSet.Count = 0 Then
            MsgBox("Wähle eine Linie, Baugruppe oder Bauteil")
            Return
        End If
        Dim selSet As SelectSet
        selSet = drawDoc.SelectSet
        Dim oSelectName As String
        If TypeOf selSet.Item(1) Is ComponentOccurrence Then
            MsgBox("Test")
            Dim oOcc As ComponentOccurrence
            oOcc = selSet.Item(1)
            Dim oDoc As Document
            oDoc = oOcc.Definition.Document
            Dim oProp As [Property]
            oProp = oDoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("BENENNUNG2")
            MsgBox(oProp.Value)
        End If
        MsgBox("Test2")
  End Sub
I hope this will help you .But i done this using VB.net ,So you need to modify this code according to your requirement.
Here you need to select a drawingcurve & that will get the component properties .So that you will get the value of that property.
'Open a assembly drawing before run this & Change properties in custom tab as per your requirement
If inventordoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
 Dim odoc As Inventor.Document
   odoc = inventorApp.ActiveDocument
  Dim oSelectSet As Inventor.SelectSet
   oSelectSet = odoc.SelectSet
   Dim oDrCurveseg As Inventor.DrawingCurveSegment
  oDrCurveseg = inventorApp.CommandManager.Pick(Inventor.SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select a drawingCurve")
             oSelectSet.Select(oDrCurveseg)
  Dim oCurve As Inventor.DrawingCurve
             oCurve = oDrCurveseg.Parent
            If TypeOf oCurve.ModelGeometry Is Inventor.EdgeProxy Then
    Dim oEdge As Inventor.Edge
                oEdge = oCurve.ModelGeometry
  Dim oBody As Inventor.SurfaceBody
                oBody = oEdge.Parent
  Dim oOC As Inventor.ComponentOccurrence
                oOC = oBody.Parent
                If oOC.DefinitionDocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
                                        odoc = oOC.Definition.Document
                    Dim oProp As Inventor.Property
                    oProp = odoc.PropertySets.Item("Inventor User Defined Properties").Item("Height")
                    Console.WriteLine(oPropSet.Value)
                End If
            End If
 End If
It worked 🙂
But I had to deaktivate   oSelectSet.Select (oDrCurveseg)
Thanks a lot 🙂
 Dim inventorApp As Inventor.Application
 Set inventorApp = GetObject(, "Inventor.Application")
   Set odoc = inventorApp.ActiveDocument
If odoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
On Error Resume Next
  Set oSelectSet = odoc.SelectSet
Set oDrCurveseg = inventorApp.CommandManager.Pick(Inventor.SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select a drawingCurve")
         '    oSelectSet.Select (oDrCurveseg)
           Set oCurve = oDrCurveseg.Parent
               Set oEdge = oCurve.ModelGeometry
             Set oBody = oEdge.Parent
             Set oOC = oBody.Parent
                                   Set odoc = oOC.Definition.Document
                    Dim oPropSet As PropertySet
                    Set oPropSet = odoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
                    Dim oProp As Property
                 '   oProp = odoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("BENENNUNG2")
                    Set oProp = oPropSet.Item("BENENNUNG1")
                    Dim oString1 As String
                    Dim oString2 As String
                    Dim oString3 As String
                    oString1 = oProp.Value
                    Set oProp = oPropSet.Item("BENENNUNG2")
                    oString2 = oProp.Value
                    Set oProp = oPropSet.Item("BEZEICHNUNG1")
                    oString3 = oProp.Value
                    MsgBox ("BENENNUNG1 = " & oString1 & " BENENNUNG2 = " & oString2 & " Bezeichnung1= " & oString3)
                End If
            End If
 End If
You need to add Selection set clear method to deactivate drawingcurve.
Something like this...
                    oSelectSet.clear( )
                End If
            End If
 End If
