[VB.net] Adobe Acrobat combined PDF
ChristianAndersenIsmyname
Message 1 of 11
Hello, I've searched the web but can't find any helpful example codes I can turn to fit my code.
What my code does right now:
  • Generates a list of all approved drawings in assembly
  • Creates PDFs of those drawings
The missing step is so combine those PDFs as one.
My code now:
Dim Acroapp As Acrobat.CAcroApp = CreateObject("AcroExch.App")
Dim files(ListBox4.Items.Count) As String
Dim Path As String = TextBox1.Text
Dim invapp As Inventor.Application
invapp = GetObject(, "Inventor.Application")
For Each itm In ListBox4.Items
   Dim x As Integer = ListBox4.Items.IndexOf(itm)
   invapp.Documents.Open(itm.ToString & "idw", True)
   invapp.ActiveDocument.SaveAs(Path & "\" & items.ToString & ".pdf", True)
   invapp.ActiveDocument.Close()
   files(x) = Path & " \ " & items.ToString & ".pdf"
Next
'Acroapp.saveas(files(), Path & "\CombinedFile.pdf") ' This is where I can't find any examples.
MsgBox("Completed")
 AcroApp doesn't show SaveAs as a option, so this is only to display what I want to achieve.
I've shortened the code to only show relevant info, and therefore some numbers/paths may be incorrect.
Thanks for any help!
Replies (10)
Message 2 of 11
yan.gauthier
In my C# Addin, I use IText so I am not 100% sure but I found this example :
Sub Button1_Click()
    Dim AcroApp As Acrobat.CAcroApp
    Dim Part1Document As Acrobat.CAcroPDDoc
    Dim Part2Document As Acrobat.CAcroPDDoc
    Dim numPages As Integer
    Set AcroApp = CreateObject("AcroExch.App")
    Set Part1Document = CreateObject("AcroExch.PDDoc")
    Set Part2Document = CreateObject("AcroExch.PDDoc")
    Part1Document.Open ("C:\temp\Part1.pdf")
    Part2Document.Open ("C:\temp\Part2.pdf")
    ' Insert the pages of Part2 after the end of Part1
    numPages = Part1Document.GetNumPages()
    If Part1Document.InsertPages(numPages - 1, Part2Document,
		0, Part2Document.GetNumPages(), True) = False Then
        MsgBox "Cannot insert pages"
    End If
    If Part1Document.Save(PDSaveFull, "C:\temp\MergedFile.pdf") = False Then
        MsgBox "Cannot save the modified document"
    End If
    Part1Document.Close
    Part2Document.Close
    AcroApp.Exit
    Set AcroApp = Nothing
    Set Part1Document = Nothing
    Set Part2Document = Nothing
    MsgBox "Done"
End Sub
Link: http://khkonsulting.com/2009/03/adobe-acrobat-and-vba-an-introduction/
Message 3 of 11
I’ve seen this example, but from my understanding this is combining the two parts that are mentioned in the code. However, my list can have 150 PDFs, the amount of documents have to be dynamic.
But I might be able to use parts of the code, but I don’t understand which line generates the new merged file.
Message 4 of 11
CadUser46
Just a thought but have you considered zipping the files instead?
I don't know your workflow but an alternative approach may yield additional benefits like searching file names etc.
Inventor 2010 Certified Professional
Currently using 2023 Pro
Message 5 of 11
Zipping isn’t a option. Reason is that this combined pdf will be sent to the mechanics who assemble the project.
The way we do it now is sorting out those 100 something files from a pdf folder (with a few thousand PDFs), and then combine the selected ones after we’ve sorted them numerically by drawing numbers.
By doing this by code every step will be significantly time saved, because finding and sorting the correct drawings will be done automatically.
Message 6 of 11
yan.gauthier
what prevent you from building a list of all files and then execute to code like in the exemple ?
I would build an array of string representing the file path of the pdf and then simply run a for loop to add them to a newly created pdf. Insert them using your loop pointer.
set newPdfFile = 'Create a new pdf file (I Don't know how with acro)
Set PartDocument = CreateObject("AcroExch.PDDoc")
for i = 0 to files.count - 1
    PartDocument.open(files(i))
    newPdfFile.InsertPages(newPdfFile.GetNumPages(), PartDocument, 0, PartDocument.GetNumPages(),false)
    PartDocument.Close
next
Message 7 of 11
 This line would be the solution I think. I havent seen any examples where something similar to this has been used.
It's basically what I have in my original post, instead of Arcobat.SaveAs(something), this line above could be used instead.
Message 8 of 11
I've made a some progress. Issue now is that it doesn't insert the pages to the PDF I've created. Hopefully someone can help me with this.
newPDF.InsertPages(-1, Line(5) & "\Combined " & asmpartnum.Value & "\" & PDFname, 1, 1, 0)
My code now creates the new PDF, and find all the PDFs that should be inserted into the new one.
It runs through everything. If I add a messagebox after the line above, it shows up.
Line(4) and Line(5) is paths I've grabbed from a txtfile. For example: C:\TEMP
Full code here:
    Private Sub Button11_Click(sender As Object, e As EventArgs) Handles Button11.Click
        Dim asmDoc As AssemblyDocument
        asmDoc = invapp.ActiveDocument
        Dim asmpartnum As Inventor.Property = Trim(asmDoc.PropertySets("Design Tracking Properties").Item("Part Number"))
        Dim PDFNewName As String
        Dim newPDF As Acrobat.CAcroPDDoc
        Dim PDFPath As String
        PDFPath = TextBox1.Text
        PDFNewName = PDFPath & "\Combined all files " & asmpartnum.Value & ".pdf"
        newPDF = CreateObject(“AcroExch.pdDoc”)
        newPDF.Create()
        newPDF.Open(PDFNewName)
        For Each items In ListBox1.Items
            For Each Doc In asmDoc.AllReferencedDocuments
                If Doc.displayname = items Then
                    Dim drawing As String = Doc.FullFileName
                    drawing = drawing.Substring(0, drawing.Length - 3)
                    Dim Drawingdocument As DrawingDocument = invapp.Documents.Open(drawing & "idw", False)
                    Dim PartnumberProp As Inventor.Property = Trim(Doc.PropertySets("Design Tracking Properties").Item("Part Number"))
                    Dim RevisionNumberProp As Inventor.Property = Drawingdocument.PropertySets("Summary Information").Item("Revision Number")
                    Dim PDFname As String = Trim(PartnumberProp.Value) & "-" & RevisionNumberProp.Value & ".pdf"
                    Drawingdocument.Close()
                    If System.IO.File.Exists(Line(4) & "\" & PDFname) Then
                        Dim fi As New System.IO.FileInfo(Line(4) & "\" & PDFname)
                        fi.CopyTo(Line(5) & "\Combined " & asmpartnum.Value & "\" & PDFname)
                    End If
                End If
            Next
        Next
        newPDF.Save(1, PDFNewName)
        newPDF.Close()
        newPDF = Nothing
        MsgBox("Complete")
    End Sub
Message 9 of 11
yan.gauthier
This line need to be different:
From the Adobe Api reference:
InsertPages(nInsertPageAfter, IPDDocSource, nStartPage, nNumPages, bBookmarks)
first doc page is 0, so it should be:
 MergePDFDocument.InsertPages(MergeDocumentLastPage - 1, SourceDocument, 0, SourceDocumentPageCount -1, false)
thus why you need to open the pdf files to know how many pages they contain.
Message 10 of 11
I'm now counting the pages of the new pdf, and the pdf it shall insert.
newPDF.InsertPages(newPages - 1, currentpdf, 0, currentPages - 1, False)
The code below does exactly the same as the code in my previous post. It creates the pdf but are unable to insert.
I think I understood what you ment, and it makes sense.
Thank you so much for the time you try to help me out.
When I get this code to work, I'll buy you a beer 😁
        Dim asmpartnum As Inventor.Property = asmDoc.PropertySets("Design Tracking Properties").Item("Part Number")
        If System.IO.Directory.Exists(Line(5) & "\Combined " & asmpartnum.Value) Then System.IO.Directory.Delete(Line(5) & "\Combined " & asmpartnum.Value, True)
        System.IO.Directory.CreateDirectory(Line(5) & "\Combined " & asmpartnum.Value)
        Dim newPages As Integer
        Dim currentPages As Integer
        newPDF.Create()
                Dim y As Integer = ListBox1.Items.IndexOf(items)
                If x = y Then
                            Dim PartnumberProp As Inventor.Property = Doc.PropertySets("Design Tracking Properties").Item("Part Number")
                            Dim sourcePDF As String = Line(4) & "\" & PDFname
                            Dim destinationPDF As String = Line(5) & "\Combined " & asmpartnum.Value & "\" & PDFname
                            If System.IO.File.Exists(sourcePDF) Then
                                newPages = newPDF.GetNumPages()
                                Dim currentpdf As Acrobat.CAcroPDDoc
                                currentpdf = CreateObject(“AcroExch.pdDoc”)
                                currentpdf.Open(destinationPDF)
                                currentPages = currentpdf.GetNumPages()
                                currentpdf.Close()
                                Dim fi As New System.IO.FileInfo(sourcePDF)
                                fi.CopyTo(destinationPDF)
                                newPDF.Close()
                            End If
                        End If
                    Next
                End If
            Next
        Next
        newPDF = Nothing
        MsgBox("Complete")
Message 11 of 11
Finally got it working!
Thanks a lot for all your help @yan.gauthier !
        ' Get inventor app
        ' Get assembly
        ' Creating directory
        If Not System.IO.Directory.Exists(TextBox1.Text) Then System.IO.Directory.CreateDirectory(TextBox1.Text)
        ' Grabbing all the info I need
        newPDF = CreateObject("AcroExch.pdDoc")
        ' Check if PDF already exists
        If System.IO.File.Exists(PDFNewName) Then System.IO.File.Delete(PDFNewName)
        newPDF.Create()
        ' Get listbox4 values (fullfilepaths without extensions)
                If x = y Then
                    ' Get document in listbox to check iProperties
                            ' Check if PDF of drawing already exists
                                ' Adds existing PDF to combined PDF
                                currentpdf = CreateObject("AcroExch.pdDoc")
                                currentpdf.Open(sourcePDF)
                                newPDF.InsertPages(newPages - 1, currentpdf, 0, currentPages - 1, True)
                                currentpdf.Close()
                            End If
                        End If
                    Next
                End If
            Next
        Next
        newPDF.Close()
        newPDF = Nothing
        MsgBox("Complete")
