vb express addin error
skyngu
skyngu
Error 2 Cannot register type library "C:\Users\aaron\AppData\Roaming\Autodesk\ApplicationPlugins\SheetMetal\SheetMetal.tlb". Error accessing the OLE registry. (Exception from HRESULT: 0x8002801C (TYPE_E_REGISTRYACCESS)) SheetMetal
i see this error when I use VB express. I use window 7 and inventor 2014 64 bit now.
can anyone fix this for me?
thanks.
Autodesk Inventor Professional 2019
YuhanZhang
Can you share more info about when you see this errors? Are you using the Inventor Wizards to create the addin? And is it possible to attach the addin project(please don't attach any confidential info) for us to reproduce the errors?
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
skyngu
hi,
I see this error when I build solution. I use inventor wizard to create addin and use its addin temperlate.
thanks.
YuhanZhang
Is the project only one just created by Inventor Wizards? Have you added other code or object to the project? Seems it failed to register OLE can you share more info about this?
Rocky Zhang
Inventor API PD
Autodesk, Inc.
skyngu
i got source code from here
http://modthemachine.typepad.com/my_weblog/2012/05/sheet-metal-extents-add-in-update.html
thanks.
