VB Code help with Custom Table Text Style
I am looking for assitance with the VB code to change the text style within a custom table when it is created from a VB standalone program.  I am using Inventor 2013 and VB 2010 Express.
I have a customtable that is created within a .idw, and I would like to have the data cells set to "Table_Cells" style that I have created.  I cannot find anything in the help file with a sample code to build off.
I figure it's got to be something with oCustomTable.DataTextStyle but beyond that I am lost.
This is what I have, and VB is kicking it back in my face.
Dim oTextStyle As TextStyle
oTextStyle = oCustomTable.DataTextStyle.StyleType("Table_Cells")
 Error    2    'Public ReadOnly Property StyleType As Inventor.StyleTypeEnum' has no parameters and its return type cannot be indexed.
This is what I'm trying to set (forgot to attach the picture)
barbara.han
You can refer to this:
Sub test()
Dim doc As DrawingDocument
Set doc = ThisApplication.ActiveDocument
doc.ActiveSheet.CustomTables.Item(1).DataTextStyle = doc.StylesManager.TextStyles.Item("Table_Cell")
End Sub
DataTextStyle is writable property. You can't change DataTextStyle.StyleType because it's read-only.
Barbara Han
Developer Technical Services
Autodesk Developer Network
Thank you for the response, that worked perfect!
