VB add-in versus VBA
I wrote a VBA Document Project routine to insert drawing borders and title
blocks. It worked fine. I wanted to create drop down menus to access it so I
redid it in VB as an add-in. It compiles fine, but when I try to run it, I
get an error unable to creat Active X component. This is caused by the
following lines:
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
Does anyone know what I am missing?
Joe
VB doesn't know what 'ThisApplication' is so you therefore have to tell it
specifically that your routine is going to be talking to Inventor. You will
need to declare a variable in one of your modules as the Inventor
Application then use this variable in place of 'ThisApplication'.
Public oApp As InventorApplication
Set oDrawDoc = oApp.ActiveDocument
Hope that helps,
Ricky
"Joe Farrell" wrote in message
news:4562961D979C63CB90D8C63B5687CEFF@in.WebX.maYIadrTaRb...
I
> following lines:
> Thanks,
> Joe
Thanks for the help. I had added oApp in the class module, but it wouldn't
work in the form.
I had to use:
Set oApp = GetObject(, "Inventor.Application")
"Ricky Lock" wrote in message
news:41CA44F379324A870ED6287C47A45E98@in.WebX.maYIadrTaRb...
will
> Hope that helps,
> Regards,
> Ricky
title
so
> I
I
> > following lines:
> > Thanks,
> > Joe
