Vault login bypass
Vault login bypass
snappyjazz
Message 1 of 29
Vault login bypass
snappyjazz
I am working on a script that's accessing content center. We are using windows authentication for our vault access, so this makes it easy to fill out the login dialog.
I would like the code to check if you're logged into vault; if not login. But I'm not having much luck getting it to work. I'm pretty sure the line under try: "SecureResults = VDF..." isn't working because the try always catches the exception. Any ideas?
Imports Connectivity.InventorAddin.EdmAddin
Imports VDF = Autodesk.DataManagement.Client.Framework.Vault
Dim SecureResults As VDF.Results.LogInResult
        Dim Conn As VDF.Currency.Connections.Connection = Nothing
        Try
            SecureResults = VDF.Library.ConnectionManager.LogIn("neb-cdmsp", "Vault", "", "", VDF.Currency.Connections.AuthenticationFlags.WindowsAuthentication, Nothing)
            If SecureResults.Success Then
                Conn = SecureResults.Connection
                MsgBox("Worked")
        Catch ex As Exception
            MsgBox("Didn't work!")
        End Try
Replies (28)
Message 21 of 29
snappyjazz
Imports System
Imports System.Type
Imports System.Activator
Imports System.Runtime.InteropServices
Imports Excel = Microsoft.Office.Interop.Excel
Imports Inventor
Imports VB = Connectivity.Application.VaultBase
Imports Autodesk.Connectivity.WebServices
Imports Autodesk.Connectivity.WebServices.WCF
Imports Autodesk.DataManagement.Client.Framework
        Dim SecureResults As Vault.Results.LogInResult
        Dim Conn As Vault.Currency.Connections.Connection = Nothing
        Try
                MsgBox("Worked")
        End Try
        End
My code is very similar. I'm even getting the message box saying "Worked". It's just not logging in. I will see if the ADMS console is getting anything.
Message 22 of 29
JamieVJohnson2
ARE WE TALKING APPLES AN ORANGES?
Apple:
You say its not logging in, but you have a connection class object 'conn' that reports .Success = true.  If that is the case YOU LOGGED IN!
BUT
"conn" only works for the objects that use it.  And those are objects you create in code as a tool.
Orange:
USER CONNECTION is a different access point that follows its own process and has its own 'connection' class object, and won't get initialized when your code logs in. Only when the Add-In logs in.  There are limited methods to effect a Vault add-in's connection, but not hook into it for coding.
At this point I am assuming you only wanted to work with Apples, a connection you can use in code for working with vault in the 'background', but if you wanted Oranges, a method that logs the user in, so the user can continue to presume they are in vault, we are barking up the wrong tree, and this large cat is about to jump down an eat us!
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
Message 23 of 29
snappyjazz
Oh shoot, I didn't know there were differences in logging in. I was looking for oranges not apples. You said: "There are limited methods to effect a Vault add-in's connection, but not hook into it for coding." In layman's terms, you can't login via coding?
Message 24 of 29
JamieVJohnson2
Using run command methods, I have seen people log into the Inventor Vault Add-in in the iLogic editor here on the forums.  This is not a process I have ever needed or wanted to perform.  Once your logged in, or out, that's all you can really do with the Add-In's connection.  You can access that connection (hook in) to preform vault tasks not performed by the user.
Message 25 of 29
snappyjazz
I must have missed those posts before I started this one. My goal is to login to the vault add-in so that my program doesn't get hung up on the login dialog box. Do you know if those run command methods operate as if a user filled out the dialog?
Message 26 of 29
JamieVJohnson2
This post may be of interest to you:
https://forums.autodesk.com/t5/inventor-customization/use-inventor-vault-add-in-through-inventor-api...
They are actually automating the InventorVault Addin, so it would know the difference (provided password and username are preset and correct).  The InventorVault Addin has not a supported API so you are 'fooling' the system to get what you want.
Message 27 of 29
snappyjazz
I feels like we're getting close, but I have just a couple of more questions. Thanks for being patient with me. The following code is provided by @bradeneuropeArthur from your link.
	 Public Sub SetupUserInterface(ByVal addInSiteObject As Inventor.ApplicationAddInSite, ByVal firstTime As Boolean, ClientID As String)
			' rest of the code should be left in here for the setupUserInterface
			'to get connection you should use the edmAddin ServerName Vault Name and username with the password you have logged in with.
            If firstTime And...................................................................
	    Dim strVaulrServerName As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.Server
            Dim strVaultName As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.VaultName
            Dim strVaultUserName As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.UserName
            Dim strVaultPassword As String = Connectivity.InventorAddin.EdmAddin.EdmSecurity.Instance.GetEdmLoginPreferences.Password
			 Dim results As VDF.Vault.Results.LogInResult
            results = VDF.Vault.Library.ConnectionManager.LogIn(strVaulrServerName, strVaultName, strVaultUserName, strVaultPassword, VDF.Vault.Currency.Connections.AuthenticationFlags.Standard, Nothing)
            Dim conn As VDF.Vault.Currency.Connections.Connection = Nothing
            If results.Success Then
                conn = results.Connection
	end sub
His code is similar to what I have except, he is using the edm to get login info, and is encased in a subroutine. The subroutine requires: an applicationaddinsite object, boolean value, and client id.
  1. What is an applicationaddinsite object? how do i create one to pass to this sub routine?
  2. None of the subroutine parameters (applicationaddinsite) are used in the subroutine; so why is it the key?
Message 28 of 29
JamieVJohnson2
Snappy, i was not able to get the easy answer for that one.  See if braden Arthur will respond since he posted it.
I'm getting the idea its using System.Reflection methods to crack into the pointer for the Inventor.Vault Add-in, then run commands that are 'assumed' to be present.  This is hacking level (aka not supported).
I thought you could simply send a command to the command editor to do log in?
Message 29 of 29
alexandru.spinu3KN9U
Jamie,
Thanks for your answers here. It helped me solve my problem 🙂
