Type Enum of Analysis Constraint
I want to know the enum type of 3 constraint types as attached image.
If it's Tangent Constraint, type enum is ContainmentEnum!?
I would appreciate any ideas/suggestions.
MinhHN.
ianteneth
Hi! I am having trouble finding out what ContainmentEnum is even related to in the API. However, I believe that for these constraints that the following properties would tell you the "directions" or "Enums", if that is what you are looking for. I haven't tested these, but I am pretty sure these are it. Hope this helps!
Symmetry Constraint
AssemblySymmetryConstraint.NormalsOpposed Property as Boolean
Insert Constraint
InsertConstraint.AxesOpposed Property as Boolean
Tangent Constraint
TangentConstraint.InsideTangency Property as Boolean
Thank you very much ^^
