Using SaveFileDialog instead of FolderBrowserDialog
Eide.N
Eide.N
Hello all, I am trying to convert a current rule to a save dialog from a folder dialog. I can't figure out how to pass the folder and filename from the dialog. Can someone help my tired brain? Here is my rule:
'Export DWG as PDF with options
	oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oDocument = ThisApplication.ActiveDocument
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
	'File Name
	Dim FileName As String
	If iProperties.Value("Project", "Revision Number") <> "" Then
		FileName = ThisDoc.FileName(False) & " Rev" & iProperties.Value("Project", "Revision Number")
	Else
	End If
	'File Path
	Dim FilePath As String = ThisDoc.Path
'Old: Dialog for choosing folder path
'New: Dialog for saving file
	Dim Dialog As New SaveFileDialog()
	'Dialog.SelectedPath = FilePath
	'Dialog.Description = "Click OK for Current Location" & vbLf & " or " & vbLf & " Select New File Location and Click OK"
	Dialog.Filter = "PDF files (*.pdf)|*.pdf|All files (*.*)|*.*"
	Dialog.DefaultExt = "pdf"
    Dialog.FilterIndex = 1
	Dialog.InitialDirectory = FilePath
	Dialog.FileName = FileName
	'If Dialog.ShowDialog() = System.Windows.Forms.DialogResult.OK Then
	If Dialog.ShowDialog() = DialogResult.OK Then
		'FilePath = Dialog.SelectedPath
		FileName = Dialog.FileName
	Else
		Exit Sub
	End If
'Chosen Path and Filename
	oDataMedium.FileName = FilePath & "\" & FileName & ".pdf"
'Write New File
	Try
		oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
		ThisDoc.Launch(FilePath)
	Catch
		MessageBox.Show("PDF not created. Please save DWG and/or close any open PDFs.", "NO PDF FOR YOU!")
	End Try
	Exit Sub
frederic.vandenplas
Hi, i hope that this is what you are looking for (note that i don't need to add the extensions so i commented them)
At the end the resulting pdf is saved and then opened which proofs i can pass the filename.
As best tip i can give is to check your variables with a messagebox or the possibility in Inventor 2019.XXX to use the this iLogic Log which new in inventor
	'File Name
	Else
	End If
	'File Path
	Else
		Exit Sub
	End If
	oDataMedium.FileName = FileName '& ".pdf"
'Write New File
	Try
		ThisDoc.Launch(FileName) '& ".pdf"
	Catch
	End Try
	Exit Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Eide.N
Frederic,
Thanks for your help! My brain was too tired to see the simple solution 🙂
Eide.N
I changed it a little to open the folder after creating instead of the file - I usually do something with the file other than just view/print it. Here is my final version:
'Set File Name
	Else
	End If
'Get Current File Path
'File Dialog
'Set File and Path from Dialog
		FilePath = System.IO.Path.GetDirectoryName(Dialog.FileName)
	Else
		Exit Sub
	End If
'Set Chosen Path and Filename
'Write New File
	Try
'Open File or Folder - Comment whichever is not wanted
		'ThisDoc.Launch(FileName)
	Catch
	End Try
	Exit Sub
Eide.N
'Set File Name
	Else
	End If
'File Dialog
	Else
		Exit Sub
	End If
'Write New File
	Try
	Catch
	End Try
	Exit Sub
