Using material iProperties in ilogic forms
Message 1 of 18
I'm trying to build a simple ilogic form to fill out iproperty infomation for parts we generate.  Our company only uses a few of fields that are available.  The problem is that the Physical tab is not available in the form editor.  I would like to add this field to my form to be able to select the material for the part.  The style/standard editor in our part template file holds all materials we use.  Summary, Project, Status, and Custom are all available, why isn't Physical?
Replies (17)
Message 2 of 18
wayne.brill
I believe you can work around this.
First create a Text Parameter. Name it something like myMaterial. (The value is the name of a material).
 Then create a rule with this conent:
iProperties..Material=myMaterial
Then add the Parameter (myMaterial) to the Form. In my tests when i change the myMaterial parameter on the Form the iProperties for the Material on the Physical Tab is updated. (and the Part changes to the new material)
I attached an ipt file with the rules and the form I used to test.
I hope this helps.
Wayne Brill
Autodesk Developer Network
Wayne Brill
Developer Technical Services
Message 3 of 18
Thanks Wayne,
Using your suggestion, I was able to take it one step further.  I setup a multi-value list parameter, then created a rule to suck in all the material data from my template file into the parameter on file startup.  I then placed the parameter on my form to allow the user to select the material they need from the list.  Then finally I had to create another rule to save-back the selection back to the iproperties physical material variable.  It sure would have been easier if Autodesk just put those variables in the forms dialog box!
Message 4 of 18
wayne.brill
I wanted to let you know that I created a Change Request with engineering to have the Physical iProperties made available on the iLogic form dialog like the other iProperties.
Wayne Brill
Autodesk Developer Network.
Wayne Brill
Message 5 of 18
I sure would like to see the code for:
" then created a rule to suck in all the material data from my template file into the parameter on file startup"
Message 6 of 18
Hello First, make sure you add the parameter in your template file for the material. [cid:image001.png@01CD5DBA.D37E1C50] Then use the rule below to populate the parameter [cid:image002.png@01CD5DBA.D37E1C50] Then use the following rule to saveback the material from the parameter to the iproperties. [cid:image003.png@01CD5DBB.43F8D1A0] And here is my event triggers to make sure it all happen automatically when you start up a new part. [cid:image004.png@01CD5DBB.43F8D1A0] Hope this helps, [cid:image005.jpg@01CD5DBB.43F8D1A0]
Message 7 of 18
is there any way you could attach a file with this in it?
Message 8 of 18
I just went back and looked at my last post. It didn't look like I expected. I took that info and cut & pasted to a .doc file. This should be easier to read. Mike Louisiana Metal-Matic Inc.
Message 9 of 18
i still dont see anything.
Message 10 of 18
Message 11 of 18
Message 12 of 18
Boy I'm sure having troubles getting my attachments to show up properly.  I'll try again to show how I set it up.
Message 13 of 18
Thank you, this works great.
Message 14 of 18
I know this post is a little old but did it ever get done?  We just upgraded to 2015 ultimate but don't see a "Physical" section in the list.
Message 15 of 18
Yes we did. we use this everyday now in our new templates.
Message 16 of 18
Hello, I'm just going thru the process of upgrading all my templates from our last version (2015 to 2017)  I wanted to streamline and get rid off all the workarounds I had to do for materials on the ilogic form.  It doesn't appear that Autodesk ever followed thru and add the physical tab to the ilogic forms?  I still don't see it.  Am I missing something?
Message 17 of 18
JanekPop
Still missing, 5 years on.
Message 18 of 18
malcolmEGTN3
Still  missing almost 10 years on...  Why do we even bother making requests.
