You can create them. Have a look at this example code:
' Get the current part document and its component definition
Dim doc As PartDocument = ThisDoc.Document
Dim def As PartComponentDefinition = doc.ComponentDefinition
' Prompt the user to select the first face for the dimension
Dim face1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter,
"Select the first face for the linear dimension.")
' Prompt the user to select the second face for the dimension
Dim face2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter,
"Select the second face for the linear dimension.")
' Prompt the user to select a face to serve as the annotation plane
Dim face3 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter,
"Select the annotation plane.")
' Create a point to place the dimension text (placeholder at origin)
Dim textPoint = ThisApplication.TransientGeometry.CreatePoint(0, 0, 0)
' Create geometry intents for the two selected faces (used by the dimension)
Dim intent1 = def.CreateGeometryIntent(face1)
Dim intent2 = def.CreateGeometryIntent(face2)
' Define the annotation plane using the third selected face
Dim annotationPlane = def.ModelAnnotations.CreateAnnotationPlaneDefinitionUsingPlane(face3)
' Get the collection of existing linear model dimensions
Dim linearDimensions = def.ModelAnnotations.ModelDimensions.LinearModelDimensions
' Create a new linear dimension definition between the two faces
Dim linDef = linearDimensions.CreateDefinition(
intent1, intent2, annotationPlane, textPoint, DimensionTypeEnum.kAlignedDimensionType)
' Add the defined dimension to the model
linearDimensions.Add(linDef)
Jelte de Jong
Blog: hjalte.nl - github.com
