using ilogic to place content centre parts into active doc (NOT ThisAssembly)
mark.almack
mark.almack
I'm trying to place some content centre components into an assembly that the rule is NOT in. So instead of "This Assembly.Geometry.Point" I need something like "ActiveAssembly.Geometry.Point." Is there such a thing?
pos = ThisAssembly.Geometry.Point(x, y, z)
Dim componentA = Components.AddContentCenterPart("Shoulder Screw:" & i, "Fasteners",
												"Automotion Components Shoulder Screw",
                                            	 ShoulderScrewName, pos, grounded := True,
                                           		 visible := True, appearance := Nothing)
 Thanks in Advance!
JelteDeJong
You can use the following code to place a occurence (or cc part) in a sub assembly.
Dim doc As AssemblyDocument = ThisApplication.ActiveDocument
Dim subAssemblyOccurence As ComponentOccurrence = doc.ComponentDefinition.Occurrences.ItemByName("Assembly1:1")
Dim subAssembly As AssemblyDocument = subAssemblyOccurence.ReferencedDocumentDescriptor.ReferencedDocument
Dim matrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix()
' TODO:
' - create Content center part if it does Not exist localy
' - get full file name
' - see: https://adndevblog.typepad.com/manufacturing/2013/06/insert-content-center-part.html
Dim occ As ComponentOccurrence = subAssembly.ComponentDefinition.Occurrences.Add(contentCenterFullFileName, matrix)
or if you want to add it to a random assembly then you can use:
Dim assemblyDoc As AssemblyDocument = ThisApplication.Documents.Open("C:\temp\assembly1.iam")
' TODO:
assemblyDoc.ComponentDefinition.Occurrences.Add(contentCenterFullFileName, matrix)
Jelte de Jong
Blog: hjalte.nl - github.com
