- Mute
- Permalink
- Report
As we use a laser cutter to produce our parts, its important that all the parts on each sheet are at the same scale. I have been trying to come up with a code which checks all the views against the first view and flags up an error message if there are any parts different. I had a code working fine, but it only checked all scales against the first part scale on the first sheet. As some of our drawings have multiple sheets, with different scales per sheet, i would like it to check each view against the view on the sheet it is on. e.g. sheet 1 should be all be at 1:1, sheet 2 should all be at 1:2. One problem is that the amount of sheets may vary, and also the names are not set, so i cant specify each sheet in the code specifically.
So far i have this, but it doesn't seem to work.
Any help will be greatly appreciated.
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document Dim oSheet As Sheet Dim oSheets As Sheets Dim oView As DrawingView Dim oViews As DrawingViews Dim oScale As Double Dim oFView As String oSheets = oDrawDoc.Sheets oViews = oSheet.DrawingViews For Each oSheet In oSheets oFView = oDrawDoc.oSheet.DrawingViews(1).Name 'adds the NAME of the first view in sheet to oFView oScale = oSheet.View(oFView).Scale 'sets the SCALE of the first view to OScale For Each oView In oViews If (oView.Scale = oScale) = False Then MessageBox.Show("Some drawing views are not the same scale", "Check Scales") End If Next Next
