- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good Morning or Afternoon,
I'm no stranger to iLogic but I'm still very much a amateur with coding, I've created code that auto creates pdfs of drawings once its saved to a specific folder or creating a fluctuating stair that changes to width and any height. But today I am asking whenever I import a file from content center and the part number in iProperties always changes, if you change the length or the size of that Content Center Part back to the default even if I changed it prior to the saved file name of that part. I want to create code that at assembly level will go through all parts and if its different then the saved ipt file it will change it to that name rather then the default content name it puts there. I've come across a few but I just would like a definitive answer or suggestions. It's been almost a year since I've touched iLogic.
