Using comboboxes in the inventor panel
Hi there,
I'm have made a ribbon panel with buttons and a comboxbox in inventor 2016 using C#.
With the code below I'm adding OnSelect handles to the com bobox.
private static void CreateComboBoxLinks(IEnumerable<ComboBoxDefinition> thecomboboxes)
foreach (ComboBoxDefinition thecombobox in thecomboboxes)
switch (thecombobox.InternalName)
case "Commando12":
thecombobox.OnSelect += Command12; //
break;
public static void Command12(NameValueMap context)
So here I want to determ which item is clikced in the combo box.
How can I cast context to a combobox ??
Or does anyone have the code to use the items in a combobox.
MessageBox.Show(context.Item[0].ToString());
MessageBox.Show(context.Value["Item1"].ToString());
MessageBox.Show(context.Name[0].ToString());
No one ? Autodesk ? Anybody ?
Okay, found it myself, so just for completeness sake:
thecombobox.OnSelect += (NameValueMap context) => DrieWHelpTools.Commando12(thecombobox);
public static void Commando12(ComboBoxDefinition bov)
MessageBox.Show(@"YOu have clicked: " + bov.ListItem[bov.ListIndex]);
Balaji_Ram
Hi Remy,
Sorry, it is not possible to know which of the combo box generated the select event from the Context information passed.
We have a request logged for it already with our engineering team.
As you see, the "Context.Count.ToString()" returns zero indicating an empty context.
The only way at present is to associate a different OnSelect callback for each of the combo boxes and access the
ListIndex of the combo box that the event handler is associated with.
However, this would not be a common event handler for a group of combo boxes.
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Hi Balaji,
Thanks for the reply. Like I wrote, I finally found a workaround.
