UserInterfaceManager.DoEvents
I am trying to adapt a VBA routine to run in 64bit Inventor and accirding to Sanjay all DoEvents have to be replaced with "UserInterfaceManager.DoEvents" but this comes up with a variable not defined error. Am I missing an include?
All other posts refering to UserInterfaceManager.DoEvents are for .NET.
Below is the code where the problem is occouring.
Public Function Initialize() As Object
    ' Initialize flag.
    bStillSelecting = True
    ' Create a new InteractionEvents object.
    Set oInteraction = ThisApplication.CommandManager.CreateInteractionEvents
    ' Set the prompt.
    oInteraction.StatusBarText = "Select a dimension."
    ' Connect to the associated select events.
    Set oSelect = oInteraction.SelectEvents
    ' Enable single selection.
    oSelect.SingleSelectEnabled = True
    ' Start the selection process.
    oInteraction.Start
    ' Loop until a selection is made.
    Do While bStillSelecting
    Loop
    ' Get the selected item.  If more than one thing was selected,
    ' just get the first item and ignore the rest.
    Dim oSelectedEnts As ObjectsEnumerator
    Set oSelectedEnts = oSelect.SelectedEntities
    If oSelectedEnts.Count > 0 Then
        Set Initialize = oSelectedEnts.Item(1)
    Else
        Set Initialize = Nothing
    End If
    ' Stop the InteractionEvents object.
    oInteraction.Stop
    ' Clean up.
    Set oSelect = Nothing
    Set oInteraction = Nothing
End Function
YuhanZhang
You can get the UserInterfaceManager through ThisApplication as below:
ThisApplication.UserInterfaceManager.DoEvents
Loop
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
It would appear that this does not work in 64bit Inventor using dotNET.  Has anyone had success with this in 64bit dotNET?
What I see is that there is no response from the inventor user inteface once we enter the loop, which would indicate that userInterfaceManager.DoEvents is not releasing processing in the 64bit 2011 Inventor?
            InventorApplication.UserInterfaceManager.DoEvents()
        Loop
BTW, commandManager.Pick exibits the same behavior in 64bit:
oSketch = DirectCast(InventorApplication.CommandManager.Pick(SelectionFilterEnum.kSketchObjectFilter, "Note"), DrawingSketch)
Instead, it needs to be split into two parts, one to initiate the process:
    Public Sub SelectDotNET(ByVal filter As SelectionFilterEnum)
        ' Initialize flag.
        ' Create an InteractionEvents object.
        oInteractEvents = InventorApplication.CommandManager.CreateInteractionEvents
        ' Ensure interaction is enabled.
        oInteractEvents.InteractionDisabled = False
        ' Set a reference to the select events.
        oSelect = oInteractEvents.SelectEvents
        ' Set the filter using the value passed in.
        oSelect.AddSelectionFilter(filter)
        ' Start the InteractionEvents object.
        oInteractEvents.Start()
    End Sub
And then an event needs to be raised back to the caller
    Private Sub oSelect_OnSelect(ByVal JustSelectedEntities As Inventor.ObjectsEnumerator, ByVal SelectionDevice As Inventor.SelectionDeviceEnum, ByVal ModelPosition As Inventor.Point, ByVal ViewPosition As Inventor.Point2d, ByVal View As Inventor.View) Handles oSelect.OnSelect
        If JustSelectedEntities.Count > 0 Then
            _SelectedObject = JustSelectedEntities.Item(1)
        Else
            _SelectedObject = Nothing
        End If
        oInteractEvents.SetCursor(CursorTypeEnum.kCursorTypeDefault)
        oInteractEvents.Stop()
        ' Clean up.
        oSelectEvents = Nothing
        oInteractEvents = Nothing
        RaiseEvent LocatedIT()
    End Sub
    Public Event LocatedIT()
scottmoyse
thanks for posting this, for some reason i wasn't e-mailed about your post even though i am subscribed to this. I will forward this onto our programmer.
cheers
Scott
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
scottmoyse
by the way it does seem to work, but it is very very very slow and sometimes it just won't work. so far from ideal.
Scott Moyse
