User name path - one drive- iLogic configuration import - %UserName%
andrew_canfield
andrew_canfield
I'd like multiple users to import the iLogic configuration setting. This works if the path is to a fixed machine (server) but not with OneDrive.
Edit %UserName% to the user's user name & everything works ok.
Regards
Andrew
CattabianiI
You could maybe use something like this snippet and execute it on Inventor start up (if you have an addin) or just when you want if you do some checks
Dim externalRuleDirectoriesList As New List(Of String)(TryCast(ThisApplication.iLogicOptions.ExternalRuleDirectories, IEnumerable(Of String)))
Dim userPath As String = System.Environment.GetFolderPath(System.Environment.SpecialFolder.UserProfile)
Dim externalRulePath As String = IO.Path.Combine(userPath, "externalRulePath")
externalRuleDirectoriesList.Add(externalRulePath)
ThisApplication.iLogicOptions.ExternalRuleDirectories = externalRuleDirectoriesList.ToArray()
