Get part number of a BOMRow with all instances supressed
jgaston
jgaston
Inventor 2022 introduced the suppress component feature in the State Master.
How can I get the properties of the BOMRow if there is no component definition?
I mean, if I can't access the component definition, how do I get the Part Number, for example?
dalton98
Hello. You will have to open the document in the background in order to view that info. How I understand it: Every file that is referenced in your current assembly is technically open but you cant see it. You can check this with "ThisApplication.Documents.Count"
Use something like this to get the part number of suppressed parts from the bom
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oBOM As BOM = oADoc.ComponentDefinition.BOM
Dim oBOMView As BOMView = oBOM.BOMViews.Item(1)
For Each oRow As BOMRow In oBOMView.BOMRows
	If oRow.ComponentOccurrences.Count = 0
		filename = oRow.ReferencedFileDescriptor.FullFileName
		Dim oDoc As Document
		oDoc = ThisApplication.Documents.Open(filename, False)
		partnumber = oDoc.PropertySets.Item(3).Item("Part Number").Value
		MessageBox.Show(partnumber)
		oDoc.Close
Next
jgaston
Thank you very much, Dalton.
I was hoping there was an alternative that would not force me to open the file, but al least, there is a roundaraound!
