Use VBA to Add Qty Req'd to Custom Properties for Components from the ****'y?
tdswanson
Message 1 of 25
tdswanson
Hello:
I'd like to create a macro that I can run from within an assembly that will loop through each BOM item and add the quantity req'd to a custom property within the component.  I'm very familiar with VBA from Office, but I'm new to it with respect to Inventor so I'm pretty fuzzy with object titles and options.  Can someone assist with the coding?
Here's an outline of what I'd like to do:
Execute Macro from within Assembly file
For Each BOM Item to # of BOM Items
  If Vendor = "Make" then
    Set Component Custom Property "Qty_Reqd" = Total Qty from BOM
  Endif
Next BOM Item
Can someone help and/or Is there an easier way?
Thanks!!
Replies (24)
Message 21 of 25
MegaJerk
Do you mean -  have it go through the component parts of the top level assembly without going through any of the sub-assemblies or their component parts?
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Message 22 of 25
Nsteel
moreso that if the top level assembly contains multiple instances of sub-assemblies "A" & "B" and parts "C" & "D"
it would only count these and not the items within "A" & "B".
Thanks.
Message 23 of 25
GosponZ
Message 24 of 25
Nsteel
Just what I was looking for.
Thanks a lot!!!
Message 25 of 25
GosponZ
I'm glad this share help. Smiley Wink
