Use Trim option by C# api
IT-Fundilusa
IT-Fundilusa
I need to use the Trim by code option, I create lines in a Sketch line1, line2, line3 and line4.
I need to trim line 4 from the end of the line to the intersection with line 2
Code:
PlanarSketch sketch = default(PlanarSketch);
sketch = partDef.Sketches.Add(partDef.WorkPlanes[3]);
TransientGeometry tg = default(TransientGeometry);
tg = ThisApplication.TransientGeometry;
Line1 = sketch.SketchLines.AddByTwoPoints(tg.CreatePoint2d(0, 10), tg.CreatePoint2d(-20, 10));
Line2 = sketch.SketchLines.AddByTwoPoints(tg.CreatePoint2d(-20, 10), tg.CreatePoint2d(-15, 0));
Line3 = sketch.SketchLines.AddByTwoPoints(tg.CreatePoint2d(0, 10), tg.CreatePoint2d(0, 5));
Line4 = sketch.SketchLines.AddByTwoPoints(tg.CreatePoint2d(0, 5), tg.CreatePoint2d(-20, 5));
florian_wenzel
i think there is no API Methode for Trim in Sketch.
Correct me if im wrong.
But you can Create new line using the Intersection Points.
The Result is similary
IT-Fundilusa
How do I get the point of intersection of two lines?
florian_wenzel
 Line4.IntersectWithCurve(Line2,)
IT-Fundilusa
The type of line4 is SketchLine and the does not have this function. 😞
florian_wenzel
Change the SketchLine into LineSegment2d.
Inventor 2022 Help | LineSegment2d Object | Autodesk
Here a sample in VB.NET
Dim oLineSegment01 As LineSegment2d
oLineSegment01 = oSketchLine01.Geometry
C# maybe 🙂
LineSegment2d oLineSegment01 =oSketchLine01.Geometry
Michael.Navara
Here is a sample code for something like Trim Function
var pick1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveLinearFilter, "Pick line 1");
var pick2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveLinearFilter, "Pick line 2");
SketchLine line1 = pick1 as SketchLine;
SketchLine line2 = pick2 as SketchLine;
var intersectWithCurve = line1.Geometry.IntersectWithCurve(line2.Geometry);
foreach (var o in intersectWithCurve)
    if (o is Point2d pt2d)
        var geometricConstraints = line1.Parent.GeometricConstraints;
        var line1StartSketchPoint = line1.StartSketchPoint;
        var line1EndSketchPoint = line1.EndSketchPoint;
        var distanceFromStart = line1StartSketchPoint.Geometry.DistanceTo(pt2d);
        var distanceFromEnd = line1EndSketchPoint.Geometry.DistanceTo(pt2d);
        if (distanceFromStart > distanceFromEnd)
            line1EndSketchPoint.MoveTo(pt2d);
            geometricConstraints.AddCoincident(line1EndSketchPoint as SketchEntity, line2 as SketchEntity);
        else
            line1StartSketchPoint.MoveTo(pt2d);
            geometricConstraints.AddCoincident(line1StartSketchPoint as SketchEntity, line2 as SketchEntity);
